- Thank you received: 12
2/3 Coil only fires half the time!!! RESOLVED :)
- clutch
- I wish I had a tad more patience to do it better!
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- Motor Head
- Thank you received: 391
classicwingclub.org/frankspage/pdf/DynaS.PDF
have you used your timing light, shining it so you can see the light flash. then move to each cylinder. If 1 is really dropping it will effect two as the coil twin fires through both. One from the center electrode to the side electrode, then the other reverse. Making a Loop. Bad plug wire or plug can cause this.
- MFolks
- Thank you received: 540
- clutch
Motor Head wrote: This is on the Dyna site, and has the trouble shooting.
Thank you for the link, it will come in handy. This may be a dumb question, but since the swap had the issue stay on the 2/3 coil, is it possible that the issue may be one of those 2 spark plugs? I would think not, but I guess it is possible for them to short out somehow. They are all brand new plugs, but sometimes I'm sure there are bad ones in the bunch.
Wish List:
Z1 (need I...
- clutch
MFolks wrote: Tried a different brand of sparkplug? I've had more than a few NGK's fail right out of the box, so I'm usung either Accel #116 or Denso W24-ESU's gapped to 0.032".
WOW! I was just posting a question asking about that while you posted the answer. Strange! I am almost certain I am using NGK, so is there a way to check the plugs, or is it just to yank them out and crank the engine looking for spark?
Wish List:
Z1 (need I...
- Motor Head
- clutch
Motor Head wrote: Did you swap the pugs over to the working coil, to eliminate that?
No! That will be the first thing I try tomorrow! I didn't think that would make the coil fire intermittently as long as they were in the engine, they're grounded so I figured that couldn't be the issue!
Wish List:
Z1 (need I...
- Motor Head
- clutch
Motor Head wrote: Measure the Ohm's in those wires also, to be sure there is no problem with a Spark plug wire.
It's on the list
Wish List:
Z1 (need I...
- clutch
Wish List:
Z1 (need I...
- Motor Head
You may have to Move the red lead to the Ohm hole on the meter. Also making sure the black is in the correct hole.
- clutch
[link] www.craftsman.com/shc/s/p_10155_12602_03...d=multimeter&prdNo=7 [/link]
Wish List:
Z1 (need I...
