- Thank you received: 391
2/3 Coil only fires half the time!!! RESOLVED :)
- Motor Head
Glad to here it is running right. Your post before where you state one coil the tach was correct and the other 1/2 made me go down a rambling path :whistle:clutch wrote: So I jumped both coil 12v feeds as well as the one for the Dyna-S (just to be certain), and I still have the same result! Coil 2/3 fires 1/2 the time, as shown by an idle rpm of 500-700 on my tach (it works correctly on the 1/4 coil). So tomorrow, I will ohm check the coil, and the wires, and if anyone has a check for the dyna-s I will run that too (may have gotten a bad one). Anything else I should check?
but now I see the part where you have the Aftermarket Electric Tach which was adjustable. I still wonder about why it would work on one coil and 1/2 on the other. The dwell could be uneven I suppose and the tach is showing that, but that is purely a guess.
Ride it and ride it some more!!
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- loudhvx
- Thank you received: 1616
Hopefully you got some miles in this evening. It feels perfect out. (I'm in DC right now... my girlfriend and I just hopped the fence to break out of the National Zoo! It closed up while we were in there. )
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- clutch
loudhvx wrote: Excellent!
No, unfortunately I had to work. It stopped raining just long enough for me to hop on and run down the street to run through the gears. It cleared up when I was at work, and I would have gotten wet on the way home....raingear is nice, but I'd rather not ride in the rain if I don't have to. Tomorrow afternoon is supposed to be ok I think.
loudhvx wrote: (I'm in DC right now... my girlfriend and I just hopped the fence to break out of the National Zoo! It closed up while we were in there. )
I KNEW the monkeys could get out of that enclosure!!! :woohoo:
LOL. J/k. The zoo closes WAY earlier than you would expect...kind of a bummer if you don't make it there until later in the day.
Wish List:
Z1 (need I...
- loudhvx
The weather is so much better than Chicago, wish we could have stayed longer.
1981 KZ550 D1 gpz.
Other links.
