- Thank you received: 1616
2/3 Coil only fires half the time!!! RESOLVED :)
- loudhvx
I think it's really up to how much you like tinkering. If you hate soldering, wiring up circuits (it sounds like you are pretty proficient at it, though), and fabricating metal, then the HEI may not be your thing. If you like learning about ignitions, and builing custom parts etc, then I see you wiring up the HEI.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- Motor Head
- Thank you received: 391
I'll tell you I also had a intermittent spark issue on my trip. I found the #3 Accel 8.8mm graphite suppression wire at fault. Not at either end, somewhere in the middle, it finally died. Have you used an OHM meter on your wires, recently, like today?
- clutch
Motor Head wrote: Are you saying that there is nothing wrong with the old, Ignitor, or the two pick-up coils?
If you explain that test to me, I will go check them...but I forgot to mention in my post above that the plug wires are new too!
EDIT: And doing the swap test that Loudhvx explained to me determined that the igniter was bad. The only thing that is still in that circuit is the power wire to the coil. Everything else has been replaced. Could it be THAT one measly little wire has been causing my woes?
Wish List:
Z1 (need I...
- Motor Head
- clutch
clutch wrote: EDIT: And doing the swap test that Loudhvx explained to me determined that the igniter was bad. The only thing that is still in that circuit is the power wire to the coil. Everything else has been replaced. Could it be THAT one measly little wire has been causing my woes?
Well...that SHOULDN't be the issue because the problem jumped to the 1/4 coil after swapping....
Wish List:
Z1 (need I...
- Motor Head
If it stays with just the same side through it all, then I would run some test wire for the Primary side. That is Hot wire the 12v feed to the suspect coil. See what that does. then Hot wire from your new Dyna, that side again straight to the coil. By pass the SOB OEM wiring and see if it makes a difference.
- clutch
Wish List:
Z1 (need I...
- Motor Head
Also what sort of Test light do you have for testing?
- clutch
Motor Head wrote: You already ran new wires to both sides of each coil, Primary wire? So new 12v Feed and Ground signal from , Now Dyna, ignitor? Soldered and heat shrinked at ends or just striped and crimped?
Stripped and crimped for now, until I rewire the whole bike. I did not run the new 12v to the coils yet, but that shouldn't be the issue because when I swapped the coils, I left the same 12v wire....I think....hmmm...maybe I should go check that sucker real quick....
Wish List:
Z1 (need I...
- Motor Head
- clutch
Motor Head wrote: If you have a decent test light, hook that to the 12v feed wire then to ground, then run the bike. It should stay lit up. It should be bright and steady. that will tell you if the 12v is going away.
I may have to run to the store for a test light...unless a neon tube would work. That's the only thing in the garage I think I have that is a 12v dc light of any kind.
Wish List:
Z1 (need I...
