2/3 Coil only fires half the time!!! RESOLVED :)
- MFolks
Re: 82 Kz 750 E cylinder #4 not firing Need help...
15 Sep 2011 01:10
The advancer needs periodic maintenance, nothing more than checking if it snaps back when twisted(engine off) and some light lubrication on the weights,spring mounting places, and the tube it rotates/moves on. Sewing machine or 3-in-one oil is what I use on my bike.
- clutch
- I wish I had a tad more patience to do it better!
15 Sep 2011 01:12MFolks wrote: Sewing machine or 3-in-one oil is what I use on my bike.
How about the oil that is used on hair clippers? Seems like that might do the trick, and I have some handy
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Wish List:
Z1 (need I...
- MFolks
15 Sep 2011 01:16
Pick up coils generally don't require much adjustment, If uncertain how it re-assembles, make note/mark around how it's mounted on the plate. Now, the advancer can be re-installed 180 degree out. To verify, try to start the engine, if no luck, take the advancer off and move it 180 & re-install & try again to start.
The following user(s) said Thank You: clutch
- MFolks
15 Sep 2011 01:18
Hair clipper(maybe Wahl?) will work, but I'm not sure how it will hold up to the engine speed and fly off.
- MFolks
15 Sep 2011 01:39
usually if a pick up coil goes bad, the ignition coil it goes to will not spark the plugs as the coil fires 2 plugs at the same time. I'm thinking maybe a sparkplug wire is bad/sparkplug cap is bad or possibly a loose connection at the ignition coil.
To tell if your ignition coil has removable sparkplug wires, see if the caps/covers have ridges on them. If not, your sparkplug wires may be molded to the coils as Kawasaki seemed to have no rhyme or reason for doing it this way.
- clutch
15 Sep 2011 02:04 - 15 Sep 2011 02:19MFolks wrote: usually if a pick up coil goes bad, the ignition coil it goes to will not spark the plugs as the coil fires 2 plugs at the same time. I'm thinking maybe a sparkplug wire is bad/sparkplug cap is bad or possibly a loose connection at the ignition coil.
I have brand new plugs, wires and coils (EDIT: and i had the same issue with the old plugs, wires and coils). I just swapped out the busted advancer with the "good one" (maybe) from my parts engine. I decided that I would tick off the neighbors and go for a quick ride down the street. The bike sounds worse to me, but maybe the springs on that other advancer are played out a bit. I took a video to hopefully help diagnose...will post that in a few
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
Last edit: 15 Sep 2011 02:19 by clutch. Reason: shown in post
- clutch
15 Sep 2011 02:12
I took this video after swapping out the advancers. The bike seems to still have the same issue. I can get it to start and idle fairly smoothly, but it still reads half the rpm (and i checked the settings on the computer). Also, battery is good voltage, and I blip the throttle a couple times so you can hear what I'm hearing...a slight hanging idle (could be idle speed too high?), a slight hiccup (kind coughs back through carbs)...sounds kind of like a lawnmower to me...
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
Re: 2/3 Coil only fires half the time!!!
15 Sep 2011 15:33 - 15 Sep 2011 15:34
Ok guys, here is what I did today. I moved the tach wire to the 1/4 coil, and it read the proper rpm reading. So, knowing that the computer is working properly, I switched the plug wires and coil wires to ensure the problem was not the plugs, coils or wires. It's not! Somewhere in the system for the 2/3 coil, there is an electrical problem causing the 2/3 coil to fire only half the time. What would cause this? What should I check now? I've searched the internet for this issue and came up with exactly nothing!!!!
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
Last edit: 15 Sep 2011 15:34 by clutch. Reason: changed topic name!
15 Sep 2011 16:27 - 15 Sep 2011 16:27
If not already done, would check for and assure good connections where the signal/trigger wires from the pickups (1) go into and out of the multiple connector between the pickups and igniter, and (2) go into and out of the multiple connector between the igniter and Dyna coils. See illustration below.
Also, if not already done, would assure the coils' primary terminal screws aren't shorting against the coil mounting spacer or elsewhere, as the screw heads are a very close fit with certain Dyna coils.
Am presupposing the new Dyna ignition coils are the correct resistance for using with the stock Kawasaki igniter style ignition system.
Attachment igniterwiringconnectorsred.jpg not found
Last edit: 15 Sep 2011 16:27 by Patton.
- clutch
15 Sep 2011 16:37Patton wrote: If not already done, would check for and assure good connections where the signal/trigger wires from the pickups (1) go into and out of the multiple connector between the pickups and igniter, and (2) go into and out of the multiple connector between the igniter and Dyna coils. See illustration below.
Sounds like a good place to start after eliminating the other choices. I'm pretty sure the terminal screws aren't grounding, but I will double check to be certain. And I am running the green 3-ohm coils...please don't tell me I got the wrong ones.... :blink:
~Clutch
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
15 Sep 2011 16:52
Everything looks ok on those connections, and the coil terminal screws aren't touching any metal. MFolks had mentioned a resistance/ohm test for the IC igniter. I don't have those listed in my repair manual, so maybe that would be a good thing to check next if someone has the test and specs they could post for me?
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
15 Sep 2011 18:00 - 15 Sep 2011 18:06
Could be mistaken, but thinking the stock '82 KZ750-E ignition coils are 1.8~2.8Ω, which seems close enough compared to the 3Ω green Dyna coils.
Might find testing procedures (including a resistance/ohm test) for the IC igniter in the manual available through the following link:
kz.bike-night.com/
To access the manual download, scroll down to and click on The Bible.
kz.bike-night.com/
Last edit: 15 Sep 2011 18:06 by Patton.
