New plunger black plugs
  • asphalt900
  • asphalt900's Avatar
Re: New plunger black plugs
20 Jul 2025 10:43 - 20 Jul 2025 10:47
#914837
Ditto what (Zed Said), poetic if you say it fast, ha. In addition, those Z900 and Z1000 26's had subtle differences. Might make sure those choke lifters on the choke rod are NOT impeding full bottoming of plungers. The 900 had different lifters then the 1000. The 900 are a double tang version and can get bent.
Last edit: 20 Jul 2025 10:47 by asphalt900. Reason: i'm goofy
  • asphalt900
20 Jul 2025 10:49
#914838
That's what Your personalized tags should say Zed1015! ZEDSAID
  • Maxbou92
  • Maxbou92's Avatar Topic Author
20 Jul 2025 10:57
#914839
I appreciate it.. I have vm28ss carb. I will try at 2 turns out. 1 and 4 cylinders are 102.5 main and 2-3 105 main!! All have 15 pilot jet
Kz750e 1980
  • Warren3200gt
  • Warren3200gt's Avatar
20 Jul 2025 11:32
#914842
Again, what bike are they on?
Thats closer to Vm24ss Z650 jetting.
  • Maxbou92
20 Jul 2025 11:34
#914843
Kz750e, vm28ss stock jetting for my carb were 102.5 and 15 pilot
Kz750e 1980
  • Warren3200gt
20 Jul 2025 11:48 - 20 Jul 2025 11:49
#914844
I thought your model came with CV carbs as original?
​​​​​​I've seen many people try to get big bore 650's out to 750 to run right on vm28's and none have managed successfully. All have eventually reverted back to 24's with stock 650 jetting (15 pilot & 102.5mains) and immediately solved all the issues.
Last edit: 20 Jul 2025 11:49 by Warren3200gt.
  • Maxbou92
20 Jul 2025 12:28
#914845
Wow ok! humm I will try to solve the black plugs.. I have to much time and effort put on the bike to again swap carbs !!  So weird to have black plugs and rebuilt carbs A to Z !!
Kz750e 1980
  • Warren3200gt
20 Jul 2025 12:45
#914846
It's not straight forward to swop from CV carbs (with butterfly's) to vm carbs with slides.
You can do the calcs for air flow for the two types mechanism used to regulate airflow.
CV carbs at say 15% open have two arched openings top and bottom of the butterfly/throat for air to flow.
VM carbs at 15% open have one segment at the bottom of the slide/throat open for air flow.
 If the throat diameters of each carb style were the same then the air flow difference is huge between the two.
The following user(s) said Thank You: Maxbou92
  • zed1015
  • zed1015's Avatar
20 Jul 2025 14:45 - 20 Jul 2025 14:52
#914853
Why have you got bigger mains in 2 and 3 ???
Don't go falling for that "centre cylinders needing bigger mains for cooling" cobblers.
You need the exact same jetting in all the carbs.
You mentioned in your private email that 2 and 3 are the darkest and the larger mains on those isn't helping so put them the same as 1 and 2..
The only reason some bikes have bigger ( or smaller ) mains in the middle cylinders is to compensate for the stock airbox design which in some cases delivers slightly differing high rpm flow rates to the outer and inner cylinders which then need different mains to correct the A/F ratio.
Once the airbox is removed on those machines all the carbs would need the same jetting.
Last edit: 20 Jul 2025 14:52 by zed1015.
The following user(s) said Thank You: Injected
  • Maxbou92
20 Jul 2025 14:52
#914854
Thats the dyno guy method!!?? I don’t know why he did that.. 102.5 and 105 in center !
Kz750e 1980
  • Injected
  • Injected's Avatar
20 Jul 2025 15:01
#914856
What is the voltage at the coils? Are you running a WG coil mod?
On one of my 650's I had 10V to coils before the coil mod, did my best to remove corrosion from bullet terminals with vinegar soak and brushing then rinse with baking soda solution.
Those old wire harnesses over the years can pick up a lot of corrosion at the bullet terminals from sitting outside. On some I have stripped the wires back to expose black copper for 6-7". The main issue for the wiring on these has mostly been thru the handlebar kill switch, a very bad design flaw!
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
  • Maxbou92
20 Jul 2025 15:57
#914858
I don’t know voltage. They are Oem coils!!  If I look at the dyno curve. It looks good to have bad fire , what do you think ?!
Kz750e 1980
