Re-Visiting the Runs like sh*t 81 GPz550
  • chopper1963
  • chopper1963's Avatar Topic Author
09 Sep 2024 07:19
#904127
The beater 1981 GPz550--STOCK--still will not come around.
Carbs are clean.
Good spark on all plugs.
Good compression
The advance/pick up is working
The timing is spot on.
Still runs like crap on the center two cylinders.
It's frustrating as all hell. The carbs are clean! There is good spark! There is good compression!
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Re-Visiting the Runs like sh*t 81 GPz550
09 Sep 2024 07:42
#904129
Have you checked "valve clearance" (big gaps will mean the valves open less ?)
The following user(s) said Thank You: chopper1963
  • chopper1963
09 Sep 2024 10:32
#904136
Not in a while but I guess I can.
The good compression all the way across leads me to believe that the valve clearance is good. Is that a bad thing?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
09 Sep 2024 10:33 - 09 Sep 2024 10:35
#904137
Tight valves will effect compression, loose ones "not so much"
Is it possible to see into the carbs when the motor is running, if so are all four slides lifting equally ?
Last edit: 09 Sep 2024 10:35 by Wookie58.
  • Nessism
  • Nessism's Avatar
09 Sep 2024 16:53
#904154
With good compression, clean carbs, and strong spark, I don't know what's left?  Could the center two exhaust pipes be plugged up?  And when you say clean carbs, did you ungang them and soak the bodies in carb dip after removing all the various parts?  Shoot carb spray through the pilot passages, and make sure it comes out the proper location on each carb?
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2024 21:28
#904162
I'd take a good look at the plugs, wires and coil. Have you used a timing light on them? You can look for a miss that way.
  • asphalt900
  • asphalt900's Avatar
10 Sep 2024 03:29
#904167
Going to take a wild guess here but i have ran across a couple Kawasaki 4cyl KZ750's that also had seemingly decent enough to start compression. Only to find out later that the head had warped, lifting 2 and 3 off their head gasket. But that's just a wild scenario i know. Being it's confined to 2/3 issues try swapping coil leads around and see if problem goes to 1/4. Have also experienced issues with the IC IGNITER and pick-ups on your era of Kawasaki. While it seemed to have decent enough spark still didn't function correctly. Switched out to a Dyna S and problem mysteriously disappeared, ha.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
10 Sep 2024 05:23
#904172
If it's cylinders 2 & 3 that points to the one thing they have in common: the coil. @Asphalt900 has good advice there. Otherwise, I would suspect the pilots are not clean on those carbs.
Question: How do you know the center two cylinders are not running well?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • chopper1963
10 Sep 2024 17:44
#904202
<<<The timing is spot on.>>>
  • Nerdy
  • Nerdy's Avatar
  • Away
10 Sep 2024 18:37
#904204
That is a good question. An infrared thermometer (~$15 from Harbor Freight) will show the temp variances in the headers - a useful piece of info.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: ThatGPzGuy, chopper1963
  • chopper1963
13 Sep 2024 08:54
#904266
Bike runs on four top and mid range. But won't run on center two at all at idle. So frustrating
  • TexasKZ
  • TexasKZ's Avatar
13 Sep 2024 09:23 - 13 Sep 2024 09:25
#904268
Makes me suspect pilot circuits, either clogged or damaged. Perhaps mixture screws with broken tips, pilot jets wallowed out or pilot passageways gouged out by too-rough cleaning?
If the low speed mixture is way off, either lean or rich, those cylinders will not fire until the rpm is high enough to transition to the main circuit.
As asked above, how are you sure the middle two are the ones not firing at idle?
Last edit: 13 Sep 2024 09:25 by TexasKZ.
