Small air filter (vents)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
06 May 2016 15:14
#724953
One of our members bought some of these for his air box. I decided to try them too. I started this thread so I wouldn't take up too much of his thread. I may be jetting after this so it could be a long one. Maybe not.
  • GPzMOD750
  • GPzMOD750's Avatar
Re: Small air filter (vents)
06 May 2016 17:00
#724960
Cool.
It'll be nice to see if it helps.
  • SWest
  • 10 22 2014
06 May 2016 17:20
#724964
Uploading a clip now. crisper rev off idle. B)
  • SWest
  • 10 22 2014
06 May 2016 18:25
#724974
Here's the clip. I'll check my plugs in the morning and after I go into town.
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 May 2016 18:57
#724976
Some members of the ZRX Owners Association tried those but that was over 10 years ago and I forget what were the adjustments needed or the results.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • SWest
  • 10 22 2014
06 May 2016 19:07
#724979
Mine are VM 33 carbs instead of 28's. The KZ 900's had 26's. Using a air box with them is unusual but that's normal for me. :lol:
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 May 2016 19:11
#724984
I was referring to the vents.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • SWest
  • 10 22 2014
06 May 2016 19:15
#724985
I know. I may not have to rejet. If I do, not by much.
  • SWest
  • 10 22 2014
11 May 2016 15:24
#725807
It was running a little lean. I could tell by the exhaust note and it started burning a little oil. I put the 70's back in. It's going to be in the 100's soon, the last thing I need is to run it too lean and overheat it,
  • SWest
  • 10 22 2014
13 May 2016 13:18
#726217
The cam doesn't do the bike justice. Audio sucks. The valve train sounds better and the exhaust has a kinda turbine sound when it's cruising in top gear. I've had it that way before but I keep FKing with it. :unsure: Had that peanut butter color on the plugs but I keep trying to lean it out and have to start over. The vents seem to help and I have the needles set on the second clip. I'll run it for a while then try to go back to the center position. I'll keep track of my MPG too. :whistle: They say the 33's were hard to tune, I think they're right. :dry:
I should have waited a few more seconds to pass but they did away with most of the passing lines out here. WHAT MORON ORDERED THAT? :angry: :angry:
  • SWest
  • 10 22 2014
28 May 2016 17:18
#729017
I'm not liking how it acts in the wind or on my trip. I'll buy some 1" plugs and block off some a couple at a time.
  • missionkz
  • missionkz's Avatar
28 May 2016 20:03
#729030
Hmmm... I noticed today, way out on the freeway in the NE flat lands of Colorado ,.... cruising too fast at about 85-90 that if I held my knees tight to the tank and around my outboard pods, the engine/bike feels normal but when I open up my knees the engine has a slight burble/surging feeling and the rpm drops a tiny bit (I can lock my twist grip throttle)... slow the bike down to 65-70 and it doesn't matter what my knees are doing. The engine is running fine.
I might break down, dump the pods and put my air box back on with some leaner carb parts if needed....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
