- Thank you received: 2755
Small air filter (vents)
06 May 2016 15:14 #724953
by SWest
Small air filter (vents) was created by SWest
One of our members bought some of these for his air box. I decided to try them too. I started this thread so I wouldn't take up too much of his thread. I may be jetting after this so it could be a long one. Maybe not.
- GPzMOD750
- Thank you received: 148
06 May 2016 17:00 #724960
by GPzMOD750
Replied by GPzMOD750 on topic Small air filter (vents)
Cool.
It'll be nice to see if it helps.
06 May 2016 17:20 #724964
by SWest
Replied by SWest on topic Small air filter (vents)
Uploading a clip now. crisper rev off idle.
06 May 2016 18:25 #724974
by SWest
Here's the clip. I'll check my plugs in the morning and after I go into town.
- Nebr_Rex
- Thank you received: 300
06 May 2016 18:57 #724976
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Small air filter (vents)
Some members of the ZRX Owners Association tried those but that was over 10 years ago and I forget what were the adjustments needed or the results.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
06 May 2016 19:07 #724979
by SWest
Mine are VM 33 carbs instead of 28's. The KZ 900's had 26's. Using a air box with them is unusual but that's normal for me. :lol:
- Nebr_Rex
06 May 2016 19:11 #724984
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
I was referring to the vents.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
06 May 2016 19:15 #724985
by SWest
I know. I may not have to rejet. If I do, not by much.
11 May 2016 15:24 #725807
by SWest
It was running a little lean. I could tell by the exhaust note and it started burning a little oil. I put the 70's back in. It's going to be in the 100's soon, the last thing I need is to run it too lean and overheat it,
13 May 2016 13:18 #726217
by SWest
The cam doesn't do the bike justice. Audio sucks. The valve train sounds better and the exhaust has a kinda turbine sound when it's cruising in top gear. I've had it that way before but I keep FKing with it. Had that peanut butter color on the plugs but I keep trying to lean it out and have to start over. The vents seem to help and I have the needles set on the second clip. I'll run it for a while then try to go back to the center position. I'll keep track of my MPG too. :whistle: They say the 33's were hard to tune, I think they're right. :dry:
I should have waited a few more seconds to pass but they did away with most of the passing lines out here. WHAT MORON ORDERED THAT?
28 May 2016 17:18 #729017
by SWest
I'm not liking how it acts in the wind or on my trip. I'll buy some 1" plugs and block off some a couple at a time.
- missionkz
28 May 2016 20:03 #729030
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic Small air filter (vents)
Hmmm... I noticed today, way out on the freeway in the NE flat lands of Colorado ,.... cruising too fast at about 85-90 that if I held my knees tight to the tank and around my outboard pods, the engine/bike feels normal but when I open up my knees the engine has a slight burble/surging feeling and the rpm drops a tiny bit (I can lock my twist grip throttle)... slow the bike down to 65-70 and it doesn't matter what my knees are doing. The engine is running fine.
I might break down, dump the pods and put my air box back on with some leaner carb parts if needed....
Bruce
1977 KZ1000A1
