Mikuni VM 33 Carbs
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Mikuni VM 33 Carbs
10 Oct 2017 19:47
#772694
Can you raise the slides and secure them in an open position, and make needle access easier?
I use a long individual allen wrench under a nut above the slide that rests on the carb top.
Would a set of Flat Slides fit and potentially perform better than the VM33's on your motor? They sure have made a difference for my engine, considering it had BS34's before. There really is no comparison.
Good luck Steve. She sounds pretty good from here. :woohoo:
1982 KZ1100-A2/1170cc sleeper 😀
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
10 Oct 2017 20:22
#772697
It can only be done one way. Not too bad.
  • SWest
  • 10 22 2014
19 Oct 2017 08:05
#773303
Plugs looked good at least up there.
  • SWest
  • 10 22 2014
29 Oct 2017 05:37
#773928
I may have to cut my slides to 1.5 cutaway. I hope not.
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
31 Oct 2017 16:04
#774060
Raised the needles.
  • SWest
  • 10 22 2014
31 Oct 2017 18:06 - 01 Nov 2017 11:58
#774065
I may have to file the slides.
Looks like the Libs didn't like over the air music in the background again. This time there's no way to respond. Uploading to a different format.
vimeo.com/240851927
Last edit: 01 Nov 2017 11:58 by SWest.
  • SWest
  • 10 22 2014
31 Oct 2017 19:46
#774070
She pulled strong to 10 5 the first two gears. Gettin there.
  • SWest
  • 10 22 2014
13 Nov 2017 17:30
#774569
I'd better do the clear tube test again.
  • SWest
  • 10 22 2014
18 Nov 2017 17:27
#774778
After 200 miles they look better.
  • SWest
  • 10 22 2014
