Having trouble leaning out my mixture [KZ200]
  • greeneman42
  • greeneman42's Avatar Topic Author
30 Dec 2015 12:54 - 30 Dec 2015 12:55
#704933
Hi, I've been using google as my main source of info into fixing my 78 KZ200 but this time I'm really stumped and thought I'd ask. So basically my problem is that I can't get the bike to idle at all. I've replaced the coil, cleaned the points, adjusted my timing and replaced the spark plug. The bike has a strong spark and the compression tested within spec of the manual. Basically what will happen is the bike will crank up with a new spark plug and idle pretty high. However, in the course of about 10 minutes, the bike will gradually require more and more throttle/ carb adjustment to keep from stalling. And once she warms up, the bike will almost always stall. It fouls the plugs with a dark sooty substance and prevents them from working anymore.
So it's running pretty rich. But I can't seem to get it to run any leaner. Stock exhaust, Keihin carburetor, stock pilot and main jet size. Carburetor is adjusted to leanest possible settings, air screw turned out, idle adjustment turned in, needle all the way down, and it shows the same symptoms. Even taking the air filter out and running the bike doesn't show much difference. I've also adjusted the float height to a little lower. Is there anything I'm missing or probably doing wrong? I'm pretty novice but I've really been doing some research and can't seem to find any issues in my method. :huh: Thanks
Last edit: 30 Dec 2015 12:55 by greeneman42.
  • loudhvx
  • loudhvx's Avatar
Re: Having trouble leaning out my mixture [KZ200]
30 Dec 2015 13:58 - 30 Dec 2015 13:58
#704937
Open the bowl and see if the main jet or pilot jet fell out. That happens sometimes right after a carb rebuild.
If the carb hasn't been rebuilt in a long time, it's possible you are idling on the main circuit (instead of the pilot circuit) because the pilot circuit is clogged.
Another possibility is the carb is overflowing gas into the engine. Normally an overflow will drain out of the carb's dedicated overflow system, but if that is clogged, the gas has nowhere to go but into the engine. As the engine warms up it will run worse under this condition.
Last edit: 30 Dec 2015 13:58 by loudhvx.
  • greeneman42
30 Dec 2015 14:30
#704941
Thank you. I'll check the overflow tomorrow to see if it's clogged. I rebuilt the carb with a rebuild kit when I first got the bike and have since taken it apart a few times after that. I'll also adjust the float height as low as the bike will allow to see if there's a difference. I didn't mention this before, but I have gone through the charging system which is outputting around 13.5 volts at idle which seems adequate. The bike is rideable but at a significant power loss and only if the throttle stays open at stops.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
31 Dec 2015 04:07 - 31 Dec 2015 04:08
#704996
Sounds electrical. Hows the battery and the connection from the coil to the plug? Also, you should disconnect and clean every single electrical connector on the bike. Lots of issues with those.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 31 Dec 2015 04:08 by Kidkawie.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Dec 2015 04:51
#705003
Check the carb holder and valve adjustments.
  • greeneman42
31 Dec 2015 15:53
#705077
Thanks. My gasket set came in today so I took the head off and unfortunately lost one of the cam sprocket screws into the crankcase :pinch: Have to go fish it out over the next couple of days. There's also a lot of carbon on the valves and valve guides and I don't have the tool to remove the valves. Would seafoam be a good way of cleaning up some of the deposits while I have it dis-assembled?
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Dec 2015 16:22
#705081
Valve guide seals. A C clamp and a piece of PVC cut out can make a valve compressor. Just use a deep socket to dislodge the keepers first.
  • TexasKZ
  • TexasKZ's Avatar
31 Dec 2015 17:10 - 31 Dec 2015 17:12
#705085
Why did you take the head off? Why remove a cam sprocket?
Last edit: 31 Dec 2015 17:12 by TexasKZ.
  • greeneman42
31 Dec 2015 17:31
#705087
I saw a gasket kit online and thought I could give the top end an overhaul while cleaning and checking that things are in spec. At this point I've really just cleaned it up really well.
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Dec 2015 17:35
#705089
When I was burning oil due to bad valve guide seals I had to go down one step on the pilot jets. Almost like a two stroke. Pics, need pics. :cheer:
  • TexasKZ
  • TexasKZ's Avatar
31 Dec 2015 17:36 - 31 Dec 2015 17:37
#705090
Wow. From mixture problems to overhaul in one tiny thread.
SQUIRREL! :woohoo:
I hope that gasket set was made in Japan. There are some pretty crappy ones out there.
Last edit: 31 Dec 2015 17:37 by TexasKZ.
  • greeneman42
31 Dec 2015 17:42
#705092
TexasKZ wrote: Wow. From mixture problems to overhaul in one tiny thread.
SQUIRREL! :woohoo:
Haha this bike allows the head to be removed with the engine still in frame so it's not too bad. I'll try and get some pics tomorrow or Saturday.
