Having trouble leaning out my mixture [KZ200]
Re: Having trouble leaning out my mixture [KZ200]
04 Jan 2016 12:07
What sort of ring compressor are you using?
It is not uncommon to trash a ring the first time.
- greeneman42
04 Jan 2016 12:22
The manual just said to use your fingers. I think I should mention I didn't replace the rings (of course now I have to though).
04 Jan 2016 12:42
With your symptoms replace the valve guide seals.
- KZB2 650
04 Jan 2016 15:15
Wondering while looking for rings and since you have it this far you should pick up a nos base gasket and head gasket...... now would be the time to lap the valves? and replace the guide seals too like mentioned ........ thinking you should hone the cylinder too to seat the new rings also..... what you guys think?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
04 Jan 2016 15:18
I think it's past slap together time.
04 Jan 2016 19:54
I wonder how all this will affect the mixture? :blink:
05 Jan 2016 05:35
If it stops burning oil, it won't run as rich.
05 Jan 2016 07:21
Man, time to slow down a little and stop making mistakes.
Get an OEM base gasket and pull the valves out of the head and replace the guide seals.
Use a 240 grit bottle brush hone, not a straight hone, and deglaze the cylinder.
Enlist the help of someone to assist when installing the cylinder over the piston. Be very careful to push the rings into the grooves in the piston before installing the cylinder down over the piston. I like to use some wood blocks to hold up the cylinder and then turn the crank to slowly push the piston up into the cylinder, as opposed to allowing the cylinder to fall down. It's much safer this way.
- greeneman42
05 Jan 2016 18:23swest wrote: With your symptoms replace the valve guide seals.
I'll have another go at them. I also ordered a new set of rings and an OEM base gasket. Why do you recommend honing the cylinder? My compression was fine previously.
05 Jan 2016 18:29
Pics of the bore and piston.
05 Jan 2016 18:40greeneman42 wrote:swest wrote: With your symptoms replace the valve guide seals.
You must hone the cylinder when installing new rings or they won't bed in and seat. 240 grit bottle brush type hone.
- Kidkawie
- I bleed premix
06 Jan 2016 04:48
Do some research on honing your cylinder. The operation takes literally 3-5 SECONDS, dont be sittting there with the hone running fubaring your cylinder.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
