vm33
- jonarmstrong
Re: vm33
21 Mar 2015 12:57
well winter is over and it's time to ride I got my float levels right a couple weeks ago and put the carbs back on the jetting seems good because just off idle and wot runs great clean and crisp everything in between sucks it's studdering not bogging the needles are on the bottom clip it doesn't seem like it's loading up more like starving I'm pretty sure I have 20pilots and 127.5mains for sure any help?
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- zukdave
Re: vm33
21 Mar 2015 15:21
Sudco list's two diff. set's of VM33's for the KZ1000
and the base line jetting is not the same for both models.
Lower right. in the pic.
www.sudco.com/Diagrams323728/expvm33.gif
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Re: vm33
21 Mar 2015 16:59
My pilots are .65, main is 127.5, throttle cut away is 2.0. Still a little rich. Good response from idle to WOT.
Check your slide bottom. Are they 1.5 or 2.0?
- zukdave
Re: vm33
21 Mar 2015 17:30
Went back and looked and I was wrong just one set
but still a good starting point.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Re: vm33
21 Mar 2015 20:57
The needles should be in the middle position while jetting.
- jonarmstrong
Re: vm33
22 Mar 2015 07:06
ok , so that being said, if I go back to middle position on needles what should I do to jetting to fix them? I have to choke the bike almost every time I start it so maybe a step up on pilots but what is gonna do anything with the ,mid throttle?
Re: vm33
22 Mar 2015 07:28
I asked what your slide cut away was. I need to know that to give you a accurate answer. If you have a 2.0 like mine, you'll need 60/65 pilots. The pilots have influence through the mid range to less and less degree. The cut away makes it richer or leaner off idle and then up. It's important. I get my pilots and mains at my local Yamaha shop. $2.99 a piece for the pilots compared to $6.99 at jetsrus. They can get me floats too.
Re: vm33
22 Mar 2015 07:29
Bear in mind you should have to use the choke when cold or it's too rich.
- jonarmstrong
Re: vm33
22 Mar 2015 07:45
I saw 1.5on the top of the slide when I adjusted needles but the guy I bought them from said the slides had been cut 60seems really big as compared to the 17.5s that were in them when I got them I do feel like it's lean on bottom because I have to use the choke every time I start it, not just when it's cold these carbs have been a PITA as compared to the bs34s I used to run I never had this much trouble w them!
Re: vm33
22 Mar 2015 07:54
The slides have been cut? That might mean they are 2.0 or 2.5. Even leaner. Split the difference and go 40's. See what that does. I'm still to rich at 65 and will try 60's. If too lean, I'll try the needle. That's only a test. I wouldn't do anything to the slides until I'm sure. I can also reopen the holes one by one on the emulsion tubes to lean it out. The PO drilled them so I soldered the ones that he added. One thing at a time.
- jonarmstrong
Re: vm33
22 Mar 2015 08:31
wow! that really comes down to a science not sure I was prepared for that guess I don't know as much as I thought I did about carbs I'll definitely try the 40s I think I have some in my big bag o jets! thanks
Re: vm33
22 Mar 2015 13:38
When I started with them there was a big flat spot just off idle. Pilots were 70's, 80 is the max, mains were at least 130's (drilled out) so I went to 127.5's to lean it out at WOT. Still too rich. I noticed all the holes the PO made. I've done this before but on 2 strokes. I soldered the extra holes and the flat spot went away. Still too rich but better. Before I did my valves I had 60's in there but it was too lean again once they were done. Now I get to start over. I have stock 1015 pistons in it now so I won't do anything besides jets or the needles until I put in my 10.25/1 Wisecos.
The nossels and needles may have been changed as well. There is a chart on jetsrus to compare to. You never know what the PO did to them.
