Is this a problem?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- keith1
- Thank you received: 2
Very easy to tell if it is a carburetor problem. Put a match to the residue or the exhaust itself while the bike is running. If it lights and blows like a torch it is a carburetor problem if not it is another problem.
good tip...also a good way to set the garage on fire....:laugh: ....
- Thank you received: 2098
Mark Wing wrote:
I think the missing jet is more of a problem, my needels move around a little and never gave me a problem.
Mark
the jet is there it was just out when i took the pic.
thank you
the jet is there it was just out when i took the pic. - - - :whistle:
- Old Man Rock
- Thank you received: 225
Anyhoot, glad the problem seems fixed due to Keith... Awesome mi amigo, way to go!
Keith now is known as K1 Coil Mod.... :blink: :woohoo:
OMR
BTW... If you want to see if oil & gas is mixed.... Scoop up a little of that mixture, places it in an open steel pan, bowl what ever and take a match to it to see if it lights.... Oil won't ignite, gas will!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bill_wilcox100
- Thank you received: 5
I just want to thank everyone for the posts. All the help is greatly appreciated.
My problem all along was a missing needle jet in carb 1.
I sent them to Keith1 on here and he cleaned them up replaced the needle jet and a bunch of other parts. He cleaned and polished the carbs and they look great and the bike runs awesome now.
here is a video of the bike running now and it shows my nice clean and shiny carbs.
Just an observation here... hard to tell from the audio on my PC but did you sync the carbs with a set of vacuum gauges?
If so, good stuff. Ride long and peacefully.
If not and my ear is correct in picking up some flutter in the idling and cam chain slap, then you may be able to significantly improve the idling (don't ask...).
Then again it could all be in my hearing. :blink: :laugh:
Best of success,
Bill
PS
Congrats on your great troubleshooting as documented in this thread. Must feel great to have gone through so much and come out on top. Way to go.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
