Is this a problem?
- davelKZ1000
I am having problems geting my 1977 kz1000 b1 ltd running right on all 4
Number one is not fireing all the time. if at all.
I have compression, have adjusted valves, have spark,
carbs are clean!!!!
when ideling if i disconnect the plug wire from number 1 i get no change. also no change if i do this when reving it.
when i ride if i goose the throttle all the way it takes right off.... if i open it up slower it hesitates at first but as it acelerates it smothes out.
Here is a pic of my Needle of number one carbed compared to number two. It does not sit strait like 2 and the rest.
IS THIS A PROBLEM? CAN IT BE MY PROBLEM? HOW DO I FIX IT?
- davelKZ1000
- Thank you received: 2098
Would suspect the #1 carb pilot circuit is causing the performance problem at lower rpms.
[Click on image to enhance view.]
Oem 1977 KZ1000 carb has pilot mixture screw (bottom located) instead of side located pilot air adjustment screw (as pictured). But the spray cleaning principals are the same.
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
I think the missing jet is more of a problem....
The needle jet is part #26.
It may be a press fit into the carb body.
- davelKZ1000
I think the missing jet is more of a problem, my needels move around a little and never gave me a problem.
Mark
the jet is there it was just out when i took the pic.
thank you
- davelKZ1000
Imo the off-center jet needle isn't a significant issue (unless it's jammed or bent), so long as its moving freely up and down inside the needle jet.
are the same.
i will try this....i will try anything! thanks for your help and the diagram.
- Old Man Rock
- Thank you received: 225
Seems they give you everything you'd need, gaskets, jets, o-rings etc...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- davelKZ1000
Why not just get 4 jet/rebuild kits ~ $120 and be done with it... If one of the carbs is jacking you, who knows about the others coming your way in frustration alone, rebuild them and be done with it... once.
OMR
i already did this. new jets, new o rings and gaskets....
disasembled carbs dipped all components rinsed them out blew them out with compressed air.
It will run on all 4 when on choke and when throttle wide open.
- davelKZ1000
[Click on image to enhance view, and watch OMR ordering carb overhaul kits.]
i took this apart again today and blew it out again.
i cannot find any blockage.
it still runs on 3 accept when on choke and wide open throttle.
does this mean the only thing it can be is still a blockage in the the carb?
is there anything else it can be?
- roy-b-boy-b
- Thank you received: 103
