Is this a problem?
08 Apr 2010 19:59 #359384 by davelKZ1000
Is this a problem? was created by davelKZ1000
Hi
I am having problems geting my 1977 kz1000 b1 ltd running right on all 4
Number one is not fireing all the time. if at all.
I have compression, have adjusted valves, have spark,
carbs are clean!!!!
when ideling if i disconnect the plug wire from number 1 i get no change. also no change if i do this when reving it.
when i ride if i goose the throttle all the way it takes right off.... if i open it up slower it hesitates at first but as it acelerates it smothes out.
Here is a pic of my Needle of number one carbed compared to number two. It does not sit strait like 2 and the rest.
IS THIS A PROBLEM? CAN IT BE MY PROBLEM? HOW DO I FIX IT?
08 Apr 2010 20:00 #359386 by davelKZ1000
Replied by davelKZ1000 on topic Is this a problem?
number 2 carb... notice how the needle is strait.
08 Apr 2010 20:11 - 09 Apr 2010 06:52 #359388 by Patton
Replied by Patton on topic Is this a problem?
Imo the off-center jet needle isn't a significant issue (unless it's jammed or bent), so long as it's moving freely up and down inside the needle jet.
Would suspect the #1 carb pilot circuit is causing the performance problem at lower rpms.
Good Fortune! :)
[Click on image to enhance view.]
Oem 1977 KZ1000 carb has pilot mixture screw (bottom located) instead of side located pilot air adjustment screw (as pictured). But the spray cleaning principals are the same.
Last edit: 09 Apr 2010 06:52 by Patton.
08 Apr 2010 20:12 #359389 by Mark Wing
Replied by Mark Wing on topic Is this a problem?
I think the missing jet is more of a problem, my needels move around a little and never gave me a problem.
Mark
Yorba Linda Cal.
08 Apr 2010 20:33 #359393 by Patton
Mark Wing wrote:
I think the missing jet is more of a problem....
The needle jet is part #26.
It may be a press fit into the carb body.
Good Fortune! :)
09 Apr 2010 06:06 #359433 by davelKZ1000
Mark
the jet is there it was just out when i took the pic.
thank you
09 Apr 2010 06:08 #359435 by davelKZ1000
Patton wrote:
Imo the off-center jet needle isn't a significant issue (unless it's jammed or bent), so long as its moving freely up and down inside the needle jet.
Good Fortune! :)
are the same.
i will try this....i will try anything! thanks for your help and the diagram.
09 Apr 2010 06:12 #359437 by Old Man Rock
Replied by Old Man Rock on topic Is this a problem?
Why not just get 4 jet/rebuild kits ~ $120 and be done with it... If one of the carbs is jacking you, who knows about the others coming your way in frustration alone, rebuild them and be done with it... once. ;)
Seems they give you everything you'd need, gaskets, jets, o-rings etc...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
09 Apr 2010 07:25 - 09 Apr 2010 07:28 #359449 by Patton
[Click on image to enhance view, and watch OMR ordering carb overhaul kits.]
Last edit: 09 Apr 2010 07:28 by Patton.
09 Apr 2010 16:32 #359561 by davelKZ1000
OMR
i already did this. new jets, new o rings and gaskets....
disasembled carbs dipped all components rinsed them out blew them out with compressed air.
It will run on all 4 when on choke and when throttle wide open.
09 Apr 2010 16:49 #359571 by davelKZ1000
i took this apart again today and blew it out again.
i cannot find any blockage.
it still runs on 3 accept when on choke and wide open throttle.
does this mean the only thing it can be is still a blockage in the the carb?
is there anything else it can be?
09 Apr 2010 16:55 #359573 by roy-b-boy-b
Replied by roy-b-boy-b on topic Is this a problem?
What were your clearances on the number one valves? Roy
