Flat spot need help (new info) and pics
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
I got the slides back today. When my tank gets here I will assemble everything and let you know how it turns out.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
If you have any problems or questions, don't hesitate to call. 630 321 0580
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Buda
The bike runs good mabe I'm being picky what do you think.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
I will give them a try
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- keith1
- Thank you received: 2
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
otto, pm sent.....
Hay Keith, I hope that you did some porting work to the head to exploit the BS34 carbs. Otherwise the engine may not produce sufficient vacuum to operate the slides properly. You have to realize that the J head on which these carburetors were used had larger valves and between 360 to 380 lift cams "stock". Your Andrews cams will at least give you the lift part of the equation.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
