Flat spot need help (new info) and pics
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
Some carbs are more difficult than others to perfect tuning throughout the range using pods.
Am thinking (but could be wrong) that the bike when new (with original carb setup, jet needle, needle jet, taper, clip, airbox, slide, etc.), would not have suffered from the mid-range flat spot.
Good Luck!
- Buda
The carbs were jetted for the pods and the pipe. It had the pods when I bought it so I dont have the air box. By the way it ran pretty well before I had the carb work done no flat spots. It has more power now just with the flat spot.
Otakar
I will check all that stuff friday and get back to you.
Thanks for your help guys.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- bountyhunter
- Thank you received: 337
I was understanding that you were wide open throttle and were hitting a flat spot at 7k RPM? If throttle is wide open, the slides should be all the way up and the main jets should be supplying nearly all the mix.First I not trying to bash WG.
I paid him to rebuild and jet the carbs for pods and the pipe. As far as what helps for the flat spot I just throttle through it, its not like it dosnt pull at all it just really comes on at 7000.
- bountyhunter
+1 From what I have read, some are virtually impossible to get to run right across the full band with pods.Wondering if pods were fitted before or after the carb work. And whether retro-fitting the oem airbox might reduce or eliminate the mid-range flat spot.
- bountyhunter
Pull ONE diaphragm cover and pull out the spring than slide out the diaphragm with the needle. Very slowly push up on the needle to slide it out of the plunger.
On mine, the diaphragm is usually stuck around the edge so you have to very carefully "peel" it away from the edge to free it. I think I may have torn one once trying to use the piston to force the diaphragm up to pull free, so that's not the way to go.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
Unless someone glued the diaphragm, It should not be stuck. Usually they fall right out. If you tear a diaphragm, you either have to replace it or I have fixed them with a piece of silk and rubber cement. Mine run perfectly threw the entire band with pods and a Kerker. I have no hesitation anywhere. Obviously we are speaking of first or second gear. You will always have some hesitation in mid range in high gears.
Yeah, I got a new set of slides with good diaphragms. Mine do tend to stick around the rim after they have been on a while, they are BS-38's maybe the BS-34's don't.
- roy-b-boy-b
- Thank you received: 103
Im running BS34s and they run good but for a flat spot from around 6000 to 7000 rpm, where do I start? I am trying to learn to work on carbs but dont know poo at this point.
Thanks for any help
Tom
Have you talked with George? Roy
- keith1
I just hit WGs profile and noticed that he last came on line 34 days ago. There are a lot of members disheartened with him.
for good reason.....
- Buda
Have you talked with George? Roy[/quote]
I really just want to learn to work on my carbs myself.
Also Im banned form his forum.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
Only one clip slot with no washers.
The hole in the bottom of the slide is .085 on an inch I think
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
