Flat spot need help (new info) and pics
- Buda
Thanks for any help
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- bountyhunter
- Thank you received: 337
- Thank you received: 2098
Im running BS34s and they run good but for a flat spot from around 6000 to 7000 rpm, where do I start? I am trying to learn to work on carbs but dont know poo at this point.
Thanks for any help
Tom
On the large fours, am thinking 6000~7000 rpm is still within mid-range carb function, influenced by jet needle clip position, slide position and cutaway design.
Plug reading may help determine whether fuel mixture is an issue in mid-range. Flat spot might result from either too rich or too lean clip position. Are different clip positions available? If only a single clip position, has it been enrichened by a small washer added under the clip? If so, perhaps the mid-range is too rich.
At 6000~7000 rpm, I would in this instance suspect the jet needle clip position as cause of the flat spot, and not the main jet size.
I don't know whether different size needle jets are available for this carb. Sometimes the corresponding Canadian model carb has a different jet needle (perhaps smaller taper) and/or a different needle jet (perhaps larger orifice) and/or several different clip positions.
The U.S. model carbs were sometimes less subject to "tuning" due to restrictive EPA regulations.
Good Luck!
- Buda
As far as checking the plugs, should I cut the engine off in that rpm range and look at them then? Sounds rite to me.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Buda
K&N pods
J cams
Vance&Hines pipe
WG rebuilt and jetted my carbs
From the carb guy
I believe we reused the OEM jet needles, used #140 main jets and #40 pilot
jets.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
I paid him to rebuild and jet the carbs for pods and the pipe. As far as what helps for the flat spot I just throttle through it, its not like it dosnt pull at all it just really comes on at 7000.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
First I not trying to bash WG.
OK than this means that the main jet is most likely good. It is a needle or slide problem. Now you have to find out what you have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
