APE Super Pro Air Filters Review w/PICS
- odl666
03 Jun 2009 21:01 #296192
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
Replied by odl666 on topic APE Super Pro Air Filters
what do i need to oil my ape filters with i had no idea i needed too?????But the filters are great and are very high quality i have had many air filters and for the price these are the best!
1979 gs750e
- athlonwirez
04 Jun 2009 10:03 #296282
by athlonwirez
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
Replied by athlonwirez on topic APE Super Pro Air Filters
Well you don't have to oil them. However, it would be highly recommended. I used K&N filter oil from a K&N recharger kit. They can be purchased at any automotive store that sells K&N products. This kit will last many years if you are only using it for these filters. They do not need much oil. Holding the spray can at least 8 inches away from the filter, lightly spray the filter surface evenly. Wipe any oil left on the rubber off with a rag, and a small amount of brake cleaner.
- saxjonz
- KawboyZ
- Thank you received: 76
16 Jun 2009 06:49 #299590
by saxjonz
79 LTD B3
Replied by saxjonz on topic APE Super Pro Air Filters
Well, that is nice to know as the K&N filters are EXPENSIVE. K&N needs to get a clue then as to what is what and charge less if the actual filter paper is the same quality as APE.
79 LTD B3
