APE Super Pro Air Filters Review w/PICS
- Bicycle Lee
19 May 2009 11:29 #292678
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic APE Super Pro Air Filters
Are there these APE filters for BS34's? I can't find dimensions, but they would need to be 54mm ID.
1978 KZ1000 police
- otakar
19 May 2009 12:01 #292685
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic APE Super Pro Air Filters
APE has 2 sizes. One size for the BS34s and the other size for the 24-29 mm carbs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- athlonwirez
21 May 2009 11:42 - 21 May 2009 11:43 #293086
by athlonwirez
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
Replied by athlonwirez on topic APE Super Pro Air Filters
I got them in today. I went home for lunch to take a look at them. They are packaged well at least.
I can tell you they are NOT as pictured on APE's website. They are NOT oval shaped. They are a tapered style. I have been told the tapered style works better, so I'm not too upset about that.
I must say I am not impressed with the design of the mating surface to the carb. The inside(actual surface that will contact the carb.) is not ribbed. That does not make me feel well about them actually staying on. Do they expect the rubber to bite the rib on on the carb. inlet in order to stay on? Also, the outside surface(where the hose clamp goes) does not have a lip to keep the hose clamp in position.
I was told they are pre oiled; however, there is no oil deposit on the plastic of the vacuum sealed package that the filters came in. There is no oil deposit left on my hand if I touch the filter element. There is no way they are oiled. I do have K&N element oil from other filters, so I can oil these, if I use them.
At least the unoiled element appears to be K&N quality.
I will post pics and measurements when I get home in a few hours. I have a gut feeling I will be tossing $10 shipping here + $10 shipping back + 20% restocking fee... if they will allow a return. If only I had the bike to at least see how they snug onto the carbs.
Last edit: 21 May 2009 11:43 by athlonwirez.
- athlonwirez
21 May 2009 15:33 #293109
by athlonwirez
- athlonwirez
21 May 2009 15:35 - 21 May 2009 15:36 #293110
by athlonwirez
Last edit: 21 May 2009 15:36 by athlonwirez.
- athlonwirez
21 May 2009 15:36 #293111
by athlonwirez
- athlonwirez
21 May 2009 15:37 - 21 May 2009 15:39 #293112
by athlonwirez
Last edit: 21 May 2009 15:39 by athlonwirez.
- athlonwirez
21 May 2009 15:37 #293113
by athlonwirez
- athlonwirez
21 May 2009 15:38 #293114
by athlonwirez
- athlonwirez
21 May 2009 15:47 #293119
by athlonwirez
- athlonwirez
21 May 2009 15:50 #293122
by athlonwirez
I will at least see how one feels on the carb. I will not be back down in SC until June 6th, so I will try it then. If I don't like it I have 30 days from today to send them back, and lose $30.
- keith1
- Thank you received: 2
21 May 2009 16:46 #293135
by keith1
Replied by keith1 on topic APE Super Pro Air Filters
