Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
Re: Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
17 Sep 2020 11:03
#835226
Yeah, I also can give these a thumbs up! The bike I used them on was a chalenging combination to tune...a 710 kitted 650 with cams and I got the bike with no carbs or air box and all I had were some vm28ss left over from kz1000 project. Before installing the air correctprs I had the bike tuned probably as good as was possible but no matter what I tried I could not get rid of a significant flat spot right at throttle crack. This made the bike very not fun to ride at low, stuck in traffic speeds. Adding to the difficulty were unidentifiable needles that must be from some type of dynojet kit and the accel pump was disabled.
After installing the air correctors, part throttle operation was immediately great. I just had to jet it back from the former configuration closer to stock. All that is left to do is get the main jets right. The most amazing thing is how easy and straightforward jetting changes have become. No guesswork. Changes yield the results expected so if you go the wrong away, you know it. Not only have the air correctors improved the tune of my 650, they have enabled me to learn so much more about carb tuning.
The following user(s) said Thank You: zed1015
  • Mikaw
  • Mikaw's Avatar
19 Sep 2020 15:01 - 19 Sep 2020 15:40
#835369
Didn’t know where else to post this so here it is.
Zed1015, the choke plungers arrived yesterday. Thank you for the diligence in such nice rebuild and in the packaging. They look great, and arrived in perfect condition.
Everything from Zed it top quality and function as depicted please do not hesitate to engage with him for the items he offers, you won’t be disappointed.
Zed1015 is just one example of the members on this forum that really live and breathe all things Kz. Like I have said before they don’t want to help you get your vintage bike just running. They want to help you get you machine running correctly! There a big difference in the two.
Last edit: 19 Sep 2020 15:40 by Mikaw.
The following user(s) said Thank You: DOHC, zed1015, Scirocco
  • zed1015
  • zed1015's Avatar Topic Author
01 Oct 2020 08:02
#835967
Some important advise for anyone sending their plungers from overseas to be re-seated.
Please be sure to send them marked as a gift and declare either zero or a low value.
Anything over £15 attracts vat etc which has to be paid before the package is released and will have to be added to the cost..
I don't have the same issue when sending them back out.
They just go as a large tracked and signed letter ( padded jiffy ) and have always got straight to the destination without any
charges.
They should be sent to me bare with the springs etc removed.
I recommend they are taped to a piece of card to secure them on their journey.
Thanks.
Rob.
  • Mikaw
  • Mikaw's Avatar
01 Oct 2020 08:10
#835968
zed1015 wrote: Some important advise for anyone sending their plungers from overseas to be re-seated.
charges.
Thanks.
Rob.
Guilty as charged. I’ll do better next time.
  • zed1015
08 Oct 2020 09:20 - 08 Oct 2020 09:22
#836393
A bit of an update on the plunger servicing.
It appears that pretty much all Mikuni and most Keihin plungers use the same 8mm diameter head.
This mean that the re-seating process ( along with the problem of leaking seats) isn't confined to just the VM carbs used on the Z's and GS fours but almost any other single, twin, triple or four etc out there that runs 8mm plungers that are no longer available new.
Price remains at £12.50 per plunger + return post tracked and signed worldwide.
Email zed.1015@yahoo.co.uk
Last edit: 08 Oct 2020 09:22 by zed1015.
  • gordone
  • gordone's Avatar
23 Jan 2021 08:21
#842239
Properly stupid question :)
When you make the threads can I just vaackum clean the metal pieces? Or must I take out all jets and high pressure air clean the carbs....
Project:
  • zed1015
23 Jan 2021 10:33
#842245
gordone wrote: Properly stupid question :)
If you are careful you can cut the threads without getting any swarf in the air bleed.
I just cut the threads with the carb mouths facing downwards slightly so that the chips fall out.
If you think any swarf has entered the air bleed you can blow compressed air up the main jet to clear it.
  • gordone
  • gordone's Avatar
26 Jan 2021 12:59
#842452
I understand the tap shall be 8mm deep, but that is because you don’t need deeper?
If you go some deeper and the jet is not flushing the surface is that a problem?
Project:
  • zed1015
26 Jan 2021 14:05
#842459
gordone wrote: I understand the tap shall be 8mm deep, but that is because you don’t need deeper?
Yes! doesn't need to be any deeper but no problem if it is.
  • gordone
  • gordone's Avatar
27 Jan 2021 01:14
#842483
Installed and carb waithing for the spring to test them :)
Project:
  • gordone
  • gordone's Avatar
28 Jan 2021 12:42
#842573
zed1015 wrote:
gordone wrote: I have recieved the jets from you and install them in winter times.
I have some questions, I have not orginal carbs I have Mikuni VM 24, orginal 650cc, but I have 750cc with 810cc bigbore upgrade.
Pilot: 17,5
Main: 112,5
Needle raised to second highest posistion.
4 to 1 exhaust and pods.
I’m 90% happy with the performance, only a issue in mid range throotle, off idle is quite okay.
When I install the air jets, what should I do with my current setup?
HI, Gordone.
If your bike was stock and you remove the airbox you would simply fit the air jets and increase the main jet a size or two.
If the needles had been raised and the pilot increased to compensate for the pods prior to fitting the air jets then they should be put back to stock and that would be it..
With your 810 i don't know what has jetting been altered and for what reason and i also think the 24mm are on the small side for that capacity and would recommend fitting 26mm from a 900 or 1000 to get the full potential from the big bore..
Having said that, with what you have i would fit the air jets first and see how that goes, the needle probably wants to go back to stock setting also i'm sure the pilots should be 15 and not 17.5 so it looks like that has been done as mentioned previously to compensate for pods and they most likely want reducing too.
Only make one change at a time though so that you know what affect it has.
Regardless of any other changes the air jets will be doing their job and any extra fueling needed will be for the capacity increase.
I have now moved the clips to 2th posistion (see picture below), before it was at 4th posistion.
These is the only adjusment I have done... is it stupid todo it, should I leave with setup I had?
I’m feeling that is wrong also since I have installed the air jets.
My thinking was, install air jets and lower the needle and see how its perform and then take it from there....
Is these stock needle posistion?
Project:
  • zed1015
28 Jan 2021 13:21
#842574
Gordone.
The clip is two slots too high .
Standard position is slot 4 counting from the top and it should be returned to that.
