Top-End Reassembly
- zed1015
Re: Top-End Reassembly
24 Oct 2025 14:10It applies to any four stroke piston.
The cam configuration bears no influence.
The following user(s) said Thank You: daveo, Street Fighter LTD
24 Oct 2025 15:56
Indeed:)
- daveo
24 Oct 2025 23:19 - 25 Oct 2025 07:59Separation improves with the Top and 2nd ring gaps flipped, in relation to the Oil Rail positions noted in the illustration.
Viewed from front:
Viewed from rear:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 25 Oct 2025 07:59 by daveo.
- daveo
27 Oct 2025 12:49 - 27 Oct 2025 12:53
The engine issue that brought about this discussion began sometime before the lengthy Carburetor subject started back in May:
kzrider.com/forum/3-carburetor/621673-rs...ease?start=60#917693
The tool I devised for seal access is wholly responsible for saving the day, though it abruptly ended my riding season.
Last edit: 27 Oct 2025 12:53 by daveo.
27 Oct 2025 13:02
What are you doing with the wobbly guide ?
- daveo
27 Oct 2025 13:49 - 27 Oct 2025 14:08What are you doing with the wobbly guide ?
The head was removed and shipped to Schumann Motor Works for guide replacement...and whatever else requires attention.
Chris Schumann ported the head and installed the valve guides for this build. He also worked on the bathtub head installed on my 82' motor.
BTW, another issue was revealed after the cylinder head was pulled...an issue with potential to do irreparable damage to the motor!
Notice anything unusual in the image below?
Last edit: 27 Oct 2025 14:08 by daveo.
- daveo
27 Oct 2025 15:15What are you doing with the wobbly guide ?
...or this one?
And these borescope images from August 6?
27 Oct 2025 16:56
Is that mechanical lovemaking down to the worn guides?
27 Oct 2025 17:25
Whats the valve look like ?
- daveo
27 Oct 2025 17:36 - 27 Oct 2025 18:22Is that mechanical lovemaking down to the worn guides?
Those were long-term relationships confined to the intake side, between all four lovers...
All that ended for good when the head came off, and they got caught!
Each piston sports a bigger pocket now...
Last edit: 27 Oct 2025 18:22 by daveo.
- daveo
27 Oct 2025 17:58Whats the valve look like ?
I don't know. The head was shipped before I thought to check.
Likely escaped damage, judging by the lack of visible markings in the oily #3 combustion chamber image below:
- daveo
