Top-End Reassembly
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Top-End Reassembly
21 Nov 2025 11:16 - 21 Nov 2025 11:47
#919222
If all else fails looks like a stout wooden finch birdhouse Daveo, ha.
Awesome suggestion!!!
The machining process went well, and the pistons just need to be smoothed out and cleaned up...
Video gets a little loud... 😱
photos.app.goo.gl/UAph1L1ZxJ6wCzeq8
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 21 Nov 2025 11:47 by daveo.
The following user(s) said Thank You: sf4t7, SWest
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
21 Nov 2025 15:07
#919228
Make sure you radius the sharp edge of the pockets to avoid “hot spots” causing pre-ignition issues. Where there’s a will there’s a way :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Nov 2025 18:54 - 21 Nov 2025 19:03
#919230
Is there enough meat left for thickness?
Last edit: 21 Nov 2025 19:03 by SWest.
  • daveo
  • Premium Member
  • Premium Member
21 Nov 2025 19:07
#919231
These bad boys are ready for action!
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • daveo
  • Premium Member
  • Premium Member
21 Nov 2025 19:46
#919233
Yes!  The flat area was lightly skimmed to blend better with the new pocket radius.
  • asphalt900
  • asphalt900's Avatar
22 Nov 2025 00:22
#919235
Sweet "finalizing" Daveo!! Now you need to call up Wiseco or parent company and sell them the rights!
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Nov 2025 07:46
#919242
Good job Dave. Being a carpenter that's something I'd try to do.
  • daveo
  • Premium Member
  • Premium Member
22 Nov 2025 13:43 - 23 Nov 2025 05:58
#919251
The edges and transition points need additional softening and blending...
Based on my experience, valve pocket modification is required to run a Wiseco K1172 piston kit in a 1983-85 ZN1100B LTD or ZX1100 engine fitted with 12044-1057 (stock ZX1100A) camshafts, and the 13001-5011 piston shown left side (modified K1172 right) in the image below:
Last edit: 23 Nov 2025 05:58 by daveo.
The following user(s) said Thank You: SWest, Wookie58
  • daveo
  • Premium Member
  • Premium Member
22 Nov 2025 21:16 - 23 Nov 2025 06:39
#919260
These pistons have been through a lot.
From this, at the end of September:
To this, near the end of November:
Good, for now...
A dusty video, while available:
photos.app.goo.gl/NvQMdq6U5rbChtwB8
Last edit: 23 Nov 2025 06:39 by daveo.
  • daveo
  • Premium Member
  • Premium Member
26 Nov 2025 20:34 - 28 Nov 2025 11:26
#919378
These two piston kits are designed to fit the same motor, but the K1173 4380M07500 valve pocket appears closer to the piston edge...much like the K1172 piston after necessary pocket modification to clear the valve:
K1172 pistons after valve pocket modification:
photos.app.goo.gl/tm99LAaw3k1nrpda9
Last edit: 28 Nov 2025 11:26 by daveo.
  • daveo
  • Premium Member
  • Premium Member
04 Dec 2025 22:44 - 08 Dec 2025 11:07
#919561
The outer valve pocket edges are manufactured 62mm apart for both K1172 and K1173 pistons.
However, the taller K1172 piston crown most likely contributed to the valve interaction that has captivated my attention for the past two-plus months.
I assume the compression ratio is no longer 10.25:1 after 1.05 +/- cubic centimeter of material was removed from each piston crown...
Probably around 10:1 now
Last edit: 08 Dec 2025 11:07 by daveo.
