Spark Plug Hole Thread Repair
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Spark Plug Hole Thread Repair
30 May 2022 12:32 - 30 May 2022 12:41
#867911
Time Sert inserts are copper plated for the heat transfer.
Found a lightly used Time-Sert M14 x 1.25 tool kit on ebay...
Just need four 44111-m14x1-25-x-660-16-8mm-washer-seat-spark-plug-inserts
Thanks y'all for the great input and suggestions!
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 30 May 2022 12:41 by daveo.
  • Mikaw
  • Mikaw's Avatar
30 May 2022 13:05
#867912
What’s the OD of the time-sent. I have a head I’m thinking of bringing back to life. One plug hole look like it was drilled our partially.
  • daveo
  • Premium Member
  • Premium Member
30 May 2022 13:12 - 30 May 2022 14:15
#867913
Last edit: 30 May 2022 14:15 by daveo.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 May 2022 14:35 - 30 May 2022 14:57
#867916
Here it comes the info.
media.wuerth.com/stmedia/wuerth/document...s/LANG_de/122295.pdf
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Last edit: 30 May 2022 14:57 by Scirocco.
The following user(s) said Thank You: daveo, Mikaw
  • Mikaw
  • Mikaw's Avatar
30 May 2022 17:02
#867921
Scirocco, thank you.
  • daveo
  • Premium Member
  • Premium Member
03 Jun 2022 19:56 - 03 Jun 2022 21:14
#868174
Time-Sert
The way to go!
Last edit: 03 Jun 2022 21:14 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jun 2022 20:58
#868178
Looks good.
  • daveo
  • Premium Member
  • Premium Member
04 Jun 2022 05:30 - 04 Jun 2022 08:40
#868189
Looks good.
The result turned out better than I expected.  And it was an easy project to do, thanks to the all-round simplicity of Time-Sert.
Side note;  After the first ride I checked compression.  Readings noted were 165 160+ 165 165
The kit:
Last edit: 04 Jun 2022 08:40 by daveo.
  • Mikaw
  • Mikaw's Avatar
04 Jun 2022 09:20
#868199
I’m curious, what’s the purpose and how does the stepped tap work.
  • Nessism
  • Nessism's Avatar
  • Away
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jun 2022 09:34
#868203
It guides the tap onto the hole using the old threads so it will be straight and true when done.
  • Mikaw
  • Mikaw's Avatar
04 Jun 2022 09:47
#868205
The stepped tap helps the tap start
I don’t see a drill, am I assuming the tape is started in the stock 14mm threads and it opens up an cuts needed threads for the sert?
