Hydro clutch or pmc easy clutch kit?
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Hydro clutch or pmc easy clutch kit?
18 Feb 2020 08:21
#819528
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationYou can find them on eBay if you watch. I got a nos one recently based on Dr gamma's recommendation.
My dad's '74 Z1
'00 ZRX1100
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Feb 2020 09:08
#819530
I made an offer on the first one.
  • Dr. Gamma
  • Dr. Gamma's Avatar
18 Feb 2020 15:37
#819545
If anyone buys a used ball bearing clutch release, they can be taken apart and rebuilt with fresh grease.
Just be careful, those little 1/8th balls will bounce all over the place when you take it apart!!!!
Been there Done that!!!!
1986 RG500G 2 stroke terror.
  • Rick H.
  • Rick H.'s Avatar
18 Feb 2020 16:20
#819547
Okay, I am confused a bit, will the 13231-020 actuator work in the KZ-1000A1? The Ebay listing for the sold new one only shows for 550 cc, 650 cc and 750 cc. and of course it didn't help that the part number on the main title was incorrect (12231-020).
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Dr. Gamma
18 Feb 2020 16:25
#819548
Rick H. wrote: Okay, I am confused a bit, will the 13231-020 actuator work in the KZ-1000A1? The Ebay listing for the sold new one only shows for 550 cc, 650 cc and 750 cc. and of course it didn't help that the part number on the main title was incorrect (12231-020).
Rick H.
BOLTS RIGHT IN!!!!!
The following user(s) said Thank You: Rick H.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
18 Feb 2020 17:51 - 18 Feb 2020 17:54
#819551
I happen to have one all apart in a baggie. This is going to be a learning curve putting it all back together. At my age I ended up with the baby duck syndrome, every time I blink my eye I'm in a new world.
Last edit: 18 Feb 2020 17:54 by 9er rider.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
19 Feb 2020 04:50
#819563
That’s easy to say in theory but in practice not practical at all if you ride lots of miles. I bought the hydra clutch (not from American klassix!) for the cost of a few clutch cables from Kawasaki. You shave a few mm from the clutch shaft and install, bleed and thereafter have a reliable clutch. Cables and changing them is not a big deal but I tend to do a lot of riding. One season I put 20k miles on my bike. I don’t want to have to lose time changing the cable in the middle of nowhere when I could be riding. I can’t say just how many times over the years this has happened. I get it that it works for you and that’s great but a cable is by no means the best solution to the problem. My hydra clutch fits right inside oem housing perfectly.
79 LTD B3
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
19 Feb 2020 05:29
#819565
79 LTD B3
19 Feb 2020 07:27
#819572
I don't doubt it, but I'm always amazed to read about cables breaking. I've put more than 62,000 miles on my bike and never had a problem with the stock Kawasaki cables. Maybe aftermarket cables are inferior or maybe the KZ1000 bikes are harder on stock Kawasaki cables than my KZ650. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Feb 2020 07:36
#819573
What kind of actuator do you have?
  • baldy110
  • baldy110's Avatar
19 Feb 2020 08:37 - 19 Feb 2020 08:41
#819575
The 650 has the ball bearing style, the good one. I've had aftermarket cables last as long as OEM one's. It's all about cleaning and lubing it regularly. I have over 160,000 miles on my KZ650 and during that time it's broken one cable, the original OEM one. It snapped at the lever end at around 45,000 miles. It was my fault and I wasn't lubing it as I should have, I replaced it with aftermarket and it's still on the bike but I've taken good care of that one.
And yes Ed the 1000 cc bikes are harder to pull due to the sucky nylon acuator.
Last edit: 19 Feb 2020 08:41 by baldy110.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Feb 2020 08:42
#819576
The Z1/KZ actuators have always been hard on cables and the hand. My mod helped but had trouble finding neutral at a stoplight.
Looks like they accepted my offer. Should have it in a few days. I know it's used and the issues that come with it but for $21.92 including shipping and tax it's worth the gamble. We'll see if it works. B)
GOD I'M GETTING CHEAP IN MY OLD AGE. :evil: :lol:
