J engine ring end gap
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: J engine ring end gap
05 Aug 2018 11:56 - 05 Aug 2018 12:03
#788247
VTEC wrote: Have you looked at the setting with a timing light? If so, was it erratic?
Yes, and No.
With engine idled up to 3500+ the timing light shows steady illumination on the Dyna degree gauge visible through the hole in the blue timing adjustment plate.  Before doing this, I determined it was important that 2/3 and 1/4 cylinders are timed correctly, so I took the following steps to assure that for my own peace of mind.  You may not wish to go through all of this monkey business, and I couldn't blame anyone for not doing so.
Being a fanatic tinkerer, I broke loose both pickups and replaced the tiny phillips-head screws with hex-head bolts, then readjusted them to fire at near identical degree settings.  They are not perfect, but very close.
Both pickups need to fire at the same degree setting.  It is a tedious process to get right, but worth the effort to assure correct balanced timing between sets of cylinders, and more importantly to gain valuable tinkering experience.  :)
To do this process, you gotta pull the spark plugs and use a 17mm wrench to manually rotate the engine clockwise direction only, around and around again, and around again...until you got it right!
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 05 Aug 2018 12:03 by daveo.
  • VTEC
  • VTEC's Avatar Topic Author
05 Aug 2018 11:59
#788248
Yes, and No.
With engine idled up to 3500+ the timing light shows steady illumination on the Dyna degree gauge visible through the hole in the blue timing adjustment plate..
See the illustration above. Is that what you're seeing at idle?
KZ1000-K2
ZRX1100
XR400R
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Aug 2018 12:11
#788249
The top one...nice and steady (above 3500 rpms).
I edited in more information which may be helpful to get my drift better for fine tuning the timing between pairs of cylinders.
Good luck and have fun playing around with it!
  • VTEC
05 Aug 2018 12:40
#788251
Ok. So yours is the same. Jumps around so bad at idle you can't read it, but smooths out at 4k.
KZ1000-K2
ZRX1100
XR400R
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Aug 2018 13:11 - 05 Aug 2018 13:28
#788252
VTEC wrote: Ok. So yours is the same. Jumps around so bad at idle you can't read it, but smooths out at 4k.
If I remember correctly, the Dynatek rotor that came with my kit does not have idle/low-rpm timing marks on it.
And I correct what I mentioned about the pickup retaining screws, which are not tiny hex-head bolts, but phillips head with a slot of a slightly larger thread size to replace the originals that striped out.
Last edit: 05 Aug 2018 13:28 by daveo.
  • VTEC
05 Aug 2018 13:16
#788253
That's true. But with my timing light I can adjust advance, line up at TDC, and read the lower advance at idle
But you did view at idle and see the mark bouncing around?
KZ1000-K2
ZRX1100
XR400R
  • VTEC
05 Aug 2018 13:31 - 05 Aug 2018 13:34
#788255
Here's the blowby. The clatter is normal from the Flatslide carbs.
Blowby
KZ1000-K2
ZRX1100
XR400R
Last edit: 05 Aug 2018 13:34 by VTEC.
  • zed1015
  • zed1015's Avatar
05 Aug 2018 13:35
#788257
That is normal.
The higher the rpm's the more stable the timing mark becomes.
The main thing is getting the full advance timing correct..
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Aug 2018 13:36
#788258
Been awhile since I checked the timing, but I recall that idle timing is automatically determined when the 3500+ rpm timing is set.  Like there is no low/idle timing adjustment available to set separately from that.
  • VTEC
05 Aug 2018 13:42 - 05 Aug 2018 13:42
#788259
That is normal.
Thanks Zed. Had a feeling it was normal. What do you think of the blowby video?
KZ1000-K2
ZRX1100
XR400R
Last edit: 05 Aug 2018 13:42 by VTEC.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Aug 2018 13:52
#788260
Sorry if I missed the point of your question, but you're welcome anyways.
  • VTEC
05 Aug 2018 13:54
#788261
daveo wrote: Sorry if I missed the point of your question, but you're welcome anyways.
Thanks daveo...
KZ1000-K2
ZRX1100
XR400R
