- Thank you received: 2870
J engine ring end gap
- VTEC
- Thank you received: 80
Nessism wrote: Earlier in the thread there is reference to how the "old rings" had shiny spots on them or something to this effect. You also mention APE doing the bore/hone work. Question: are you working with a new top end or has it been run previously? If run previously, how did the bores look in terms of scoring, did everything get measured, and was a fresh hone job performed? Reason for asking is that if this is a new top end and APE bore the cylinders, something bad happened to leave those score marks in the bores.
Bored by APE, new pistons n rings. First run, and this is what I got. Think It's got to be excessive heat, or fuel wash that caused the damage while tuning.
KZ1000-K2
ZRX1100
XR400R
- Thank you received: 2769
- VTEC
zed1015 wrote: Must have been very cold/ damp to cause that but slight brown staining shouldn't have done anything.
As regards the cause ,who knows ? without pulling it apart but If it runs ok otherwise I would give it a chance and do a few hundred miles and see if it settles.
20 miles isn't enough for a determination unless something drastic happened.
I'm thinking the same thing, but know deep down it will never be 100% without hone, pistons n rings, again.
The advantage would be getting the carbs tuned, and figuring out my mystery intermittent no spark issue, before doing the top end again.
Disadvantage is dirty oil, and carbon build up in the head.
Right now I see blowby smoke out the breather, but not the exhaust. But there's already carbon on top of the pistons after 20 miles.
KZ1000-K2
ZRX1100
XR400R
- VTEC
KZ1000-K2
ZRX1100
XR400R
- VTEC
SWest wrote: Well the rings might seat in if it runs properly. Mine's getting better all the time.
We'll see, but I'm not getting my hopes up. From expeirience the borescope view can exaggerate damage, but the smoke out the breather doesn't lie.
KZ1000-K2
ZRX1100
XR400R
- VTEC
KZ1000-K2
ZRX1100
XR400R
- VTEC
KZ1000-K2
ZRX1100
XR400R
- Thank you received: 2107
Drive carefully without anger!!!
