J engine ring end gap
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: J engine ring end gap
27 Jul 2018 15:26 - 27 Jul 2018 15:28
#787756
SWest wrote:
Looks like wrong crosshatch. What do the rings look like?
This requires to pull the head, i would bit the bullet to confirm the scorings on the rings and pistons.
Last edit: 27 Jul 2018 15:28 by Scirocco.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2018 15:40
#787757
Looks like the head is already off. Is it a overbore? If so it was a lousy job and the hone wouldn't clean it up. I suspect particles of metal scored the bores.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
27 Jul 2018 15:53 - 27 Jul 2018 15:56
#787758
Could be an endoscope view through the spark plug bore.
VTEC know the answer.
Last edit: 27 Jul 2018 15:56 by Scirocco.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2018 15:58
#787759
In any event the horizontal grooves would cause ring "chattering." My next question would be the piston/wall clearance.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2018 16:19
#787762
After looking at it again it looks like the marks stop at the top ring. Must have happened after first install.
  • VTEC
  • VTEC's Avatar Topic Author
27 Jul 2018 18:46
#787772
Engine is still together. Pics are with a borescope through the plug hole. Marks go all the way to the top of the bore, above the top ring. Not there on assembly.
KZ1000-K2
ZRX1100
XR400R
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2018 18:50
#787773
I'm afraid you're going to have to open it back up.
  • VTEC
27 Jul 2018 19:35
#787775
SWest wrote: I'm afraid you're going to have to open it back up.
I know. Really sucks. Just want to be sure of the cause so it doesn't happen again.
KZ1000-K2
ZRX1100
XR400R
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2018 19:47
#787776
Should be obvious.
  • zed1015
  • zed1015's Avatar
28 Jul 2018 01:02
#787782
Were the bores washed with clean soapy water after boring and not just solvent ?
If not it's scuffing from the honing grit still trapped in the hatching.
  • VTEC
28 Jul 2018 04:32 - 28 Jul 2018 04:34
#787785
zed1015 wrote: Were the bores washed with clean soapy water after boring and not just solvent ?
Yes, I scrubbed the hell out of them. But I did have an issue with flash corrosion within a minute of washing before I could get them dry. Rubbed them down with ATF to take it off, but if you look closely you could still see a hint of rust color. Everybody said don't worry about it.
You think fuel wash or a heat issue could have caused this?
KZ1000-K2
ZRX1100
XR400R
Last edit: 28 Jul 2018 04:34 by VTEC.
  • zed1015
  • zed1015's Avatar
28 Jul 2018 05:30
#787788
Must have been very cold/ damp to cause that but slight brown staining shouldn't have done anything.
As regards the cause ,who knows ? without pulling it apart but If it runs ok otherwise I would give it a chance and do a few hundred miles and see if it settles.
20 miles isn't enough for a determination unless something drastic happened.
