Gpz 750 head is bowed slightly
  • jenningsjesse
  • jenningsjesse's Avatar Topic Author
Re: Gpz 750 head is bowed slightly
05 Sep 2017 11:19
#770388
When I get it back apart will do.
  • TexasKZ
  • TexasKZ's Avatar
06 Sep 2017 06:06
#770444
You know the KZ1000 has removable cam bearings, right? Are you looking at a damaged plain bearing?
  • jenningsjesse
06 Sep 2017 11:35
#770464
Yeah I didn't have enough light or time, was focused on valve adjustment. I should be able to just replace bearings then. If not, I'll chime in again. For future reference though, if a journal on a 750 ever became scarred, can you machine those heads?
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Sep 2017 15:25
#770474
I have some I just replaced. Most are still good.
