Very low compression after head gusket replacment
  • dimanya
  • dimanya's Avatar Topic Author
Re: Very low compression after head gusket replacment
15 May 2016 13:22
#726562
Test drive what and how? Dont get the question
1982 Kawasaki KZ1000 Police
  • dimanya
15 May 2016 13:31
#726563
Thanks. I'll try test. Well engine has like 12 k on it and compression was good 150-170 on all 4 cylinders before I disassemble it . Now no valve clearance on 1 valve on each of 3 cylinders. So the only clue here is the dude that did it mixed up shims and valves do not seal properly. My question is how did it fire and run on compression 60-70 on 3 cylinders. All were firing. It worked like shit though
  • dimanya
15 May 2016 13:35
#726565
If i take shims off all together just to test the compression. Will I damage cam shafts? What do you think?
  • dimanya
15 May 2016 13:57
#726568
Btw whats the smalles shim that's available for these bikes. Just want to get one so I can test clearance. Smallest I found on ebay 2.00
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 May 2016 14:02
#726570
That's the smallest.
The following user(s) said Thank You: dimanya
  • TexasKZ
  • TexasKZ's Avatar
15 May 2016 14:06
#726573
dimanya wrote: If i take shims off all together just to test the compression. Will I damage cam shafts? What do you think?
Yes. Cam lobes will get damaged.
  • Nessism
  • Nessism's Avatar
15 May 2016 15:13
#726594
Never rotate the engine with a shim removed. As mentioned, the camshafts will be damaged.
If the only thing stopping you from adjusting the valves is not having the tool, read this... members.dslextreme.com/users/bikecliff/i...lve_tool_zip_tie.pdf
The following user(s) said Thank You: PLUMMEN
  • dimanya
21 May 2016 20:24
#727818
Got tools and 2.0 shim + micrometer to measure original shims (some lost markings on them). I think I found where they need to be moved after whole day of calculations and measurements.
But now i found 2 more issues. The one that is most serious is that bucket on intake #3 is very tight. There are metal shaving all over the bucket on the valve cover and under the shim. You can only turn it in place with screwdriver with quiet a bit force while others rotate freely. The only way I could take it out is with biters. Took a bucket from other cylinder and it was stuck there to. So its definitely not a bucket it self. Any ideas? Don't want to take heads off again but it seems I might have to.
#2 issue treads on cam shaft caps were helicoiled and 1 was pulled out because I did the mistake that everyone else was doing started to tighten it to 12ft lb. So i guess will have to go to a bigger size now on 1 of the wholes.
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2016 20:31
#727820
Unless you can make it move freely, you'll have to take off the head and remove the valve. Have you tried to vacuum it out?
  • dimanya
21 May 2016 21:42
#727834
swest wrote: Unless you can make it move freely, you'll have to take off the head and remove the valve. Have you tried to vacuum it out?
Hey man. What do you mean vacuum it out? Bucket? Yea I can take bucket out with biters or pliers, Strong magnet does not pull it. Very tight. Is that what you meant? What could cause it to be so tight in there that's the question I really like to know the answer to?
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 May 2016 05:43
#727848
Where did the metal shavings come from? That's what's causing it. Pull the head.
  • dimanya
22 May 2016 08:58
#727871
Ok will do that. I want electric bike getting tired of this internal combustion bs:)
swest wrote: Where did the metal shavings come from? That's what's causing it. Pull the head.
