Very low compression after head gusket replacment
  • spdygon
  • spdygon's Avatar
Re: Very low compression after head gusket replacment
23 May 2016 13:40
#728064
Looks like your Mechanic did not mark or keep track of were things come out of.
Buckets , valves , bearings , etc should go back in the same place they were remove.
You are going to end up with a trash motor.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2016 13:41
#728067
Not necessarily. :whistle:
  • spdygon
  • spdygon's Avatar
23 May 2016 14:00
#728072
Ok....
1974 Z1 900 project
  • PLUMMEN
  • PLUMMEN's Avatar
23 May 2016 19:23
#728160
Pull the head off and check everything again. I think you need to remove the tensioner before reinstalling the valve cover on that motor also since its a j series,not a kz. ;)
  • dimanya
  • dimanya's Avatar Topic Author
23 May 2016 22:35
#728182
You right well lets see if bucket will fit properly after I am done with it.
1982 Kawasaki KZ1000 Police
  • dimanya
23 May 2016 22:40
#728183
I might need another head. I made (12ftlb ) mistake and pulled treads on #4 cam caps just one hole. It was helicoiled before so now I will try to get it to m7 size helicoil and m7 bolt does not fit. I need to drill cap out. May be I should just part the dam thing
