Pulled head and found 1 oily combustion chamber
  • Dirtyhands
  • Dirtyhands's Avatar Topic Author
11 May 2016 19:49
#725865
Hello all. I had to pull the head off my bike so that I could helicoil a stripped cam bolt hole. That job is done but I noticed while all the combustion chambers had quite a bit of carbon build up (That I intend to clean off) One of them is oily. What does it mean? is there anything I need to do while I have the head off (valve seals?) I bought a new head gasket and oil seal but do I have to replace the base gasket even though I haven't lifted the jug?
Thank you,
Zac
Attachment IMG_0247(1).JPG not found
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Pulled head and found 1 oily combustion chamber
11 May 2016 19:52
#725866
Valve guide seals yes. What does that bore look like?
  • Dirtyhands
11 May 2016 20:08
#725868
Hears some pictures of the cylinder bore
Attachment IMG_0249.JPG not found
Attachment IMG_0252.JPG not found
Attachment IMG_0250.JPG not found
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 20:11
#725869
Need to see the oily one.
  • Dirtyhands
11 May 2016 20:17
#725871
Oops, here it is. Compression before dis-assembly w
Attachment IMG_0254(1).JPG not found
Attachment IMG_0253.JPG not found
Attachment IMG_0255.JPG not found
as in line with the other cylinders 155
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 20:46
#725874
Looks like it had just been honed. Maybe a broken ring. I'd check the guide seals first.
  • Dirtyhands
11 May 2016 21:39
#725880
Compression was 155 in that cylinder before I pulled the head. Right in line with the others. Would it be a lot lower if a ring was busted?
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2016 05:05
#725896
Could be oil ring.
  • wrenchmonkey
  • wrenchmonkey's Avatar
12 May 2016 06:07
#725902
Dirtyhands wrote: Hello all. I had to pull the head off my bike so that I could helicoil a stripped cam bolt hole. That job is done but I noticed while all the combustion chambers had quite a bit of carbon build up (That I intend to clean off) One of them is oily. What does it mean? is there anything I need to do while I have the head off (valve seals?) I bought a new head gasket and oil seal but do I have to replace the base gasket even though I haven't lifted the jug?
Hey Zac!
Just curious, could it be possible that "oily-ness" is just penetrating oil that leaked in to that cylinder during the head removal?
The reason I ask is.
1) You mentioned good and equal compression.
2) That spark plug looks pretty much like the other - not all blackened but so-called "coffee and cream" which is good; right?
3) In the photo, there appears to be some shiny hazy glow between the oiling port (where the oblong oil seal goes) that wraps around the cylinder head / bore in question. As though maybe something leaked in and around that head recently.
My vote is to replace the valve stem seals.
Viton valve stem seals are inexpensive and you are there now. I had the machine shop replace them on KZombie's cylinder head a week ago.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2016 06:17
#725903
Yet to see the oily piston.
  • Dirtyhands
12 May 2016 10:39
#725953
Believe it or not the last set of pictures were of the piston that chamber went with. The Piston is as dry and sooty as the others. only the combustion chamber is oily
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
  • Dirtyhands
12 May 2016 10:51
#725956
Hey wrenchmonkey I think your onto something. Especially since the piston looks normal. I also have a feeling I know when the oil came past the oring. When I was removing the head I tried to follow the manuals advise and pop the head loose by kicking the engine over. I bet the oil squeezed by then. I ordered some viton seals though. I'm honestly considering a new head if I'm pulling valves. There are 3 helicoils in this one and probably more on the way (due to inexperience and overtorquing). A fresh start might be nice.
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
