kz1000 engine cases
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kz1000 engine cases
04 Dec 2015 09:45
#701878
The cases should be a matched pair. Otherwise you will have fitment issues.
  • mrdatsunturbo
  • mrdatsunturbo's Avatar Topic Author
  • mrturbo Norway
04 Dec 2015 09:49
#701880
Yes the ST cases are matched pair but i am not shure if my cranck and gear from Z1R will fit?
  • floivanus
  • floivanus's Avatar
04 Dec 2015 09:55
#701881
It'll fit, use the cases and all your parts
Past; 78 kz1000, 83 kz550
Andrew
  • mrdatsunturbo
  • mrturbo Norway
04 Dec 2015 09:58
#701882
Thanks a lot ,this saved my day. :) :)
  • floivanus
04 Dec 2015 10:38
#701893
There's two spots for the shifter arm/selector, use the one that matches your trans door, the other one is for the shaft drive setup, ignore it
Andrew
  • mrdatsunturbo
  • mrturbo Norway
08 Dec 2015 20:11
#702475
I talked to the welder and he looked at my engine case.
So if is welding this it will need a line bore/hone after weld process?
Ok so we talked about what to do and we will try a Big Time sert insert .
Never tried this before but looks good and also perfect measurments for this repair.Updates this when done and also told
you that it is cylinder stud,its not it is crank bearing side. :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Dec 2015 06:28
#702510
It's not the crank bearing? Sure looked like it. The cylinder stud is easy compared to that. Got some wiggle room there. ;)
  • mrdatsunturbo
  • mrturbo Norway
09 Dec 2015 08:08
#702518
yes it is crank bearing, thinking Norwegian and typing same :dry:
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Dec 2015 08:46
#702524
He can fill the hole, file it even, put the bearing in and cap, then start the new hole with the cap in place. That's how I'd do it anyway. :unsure:
  • PLUMMEN
  • PLUMMEN's Avatar
10 Dec 2015 17:31
#702671
swest wrote: He can fill the hole, file it even, put the bearing in and cap, then start the new hole with the cap in place. That's how I'd do it anyway. :unsure:
Id say its way to close to bore where main bearing sits,by the time you get the hole welded up I think youd warp too many machined areas. ;)
  • mrdatsunturbo
  • mrturbo Norway
25 Dec 2015 22:37 - 25 Dec 2015 22:40
#704375
So i did some work last days and i hope the result is good, but do you think it is good enough?
First thing ,cleaning, Loctite repair compound,cured 72 hours, then i mounted a big time sert.i made up a simple drill jig alumium plate.
As seen on one of the Pictures i order a extra lenght Insert. I t is my first experience wite time sert and it felt very solid.But the last Picture is number one, not shure why that happend. Rune
Attachment IMG_0117.jpg not found
Attachment IMG_0125.jpg not found
Attachment IMG_0126.jpg not found
Attachment IMG_0127.jpg not found
Attachment IMG_0128.jpg not found
Attachment IMG_0129.jpg not found
Attachment IMG_0130.jpg not found
Attachment IMG_0131.jpg not found
Attachment IMG_0116.jpg not found
Last edit: 25 Dec 2015 22:40 by mrdatsunturbo. Reason: wrong spelling
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Dec 2015 04:03
#704386
Looks like the Time Cert has a good bight 3/4 the way around. Just might work. B)
