- Thank you received: 2
kz1000 engine cases
- mrdatsunturbo
- mrturbo Norway
03 Dec 2015 04:34 #701681
by mrdatsunturbo
kz1000 engine cases was created by mrdatsunturbo
previous owner broke one cylinder stud in the engine case, this will need some welding.
so a kz1000 st shaft engine case, is this a good idea to replace my broken one?thanks .Norway
- Thank you received: 2063
03 Dec 2015 05:15 #701686
by Street Fighter LTD
Replied by Street Fighter LTD on topic kz1000 engine cases
Are you thinking a case needs to be replaced because a main stud is broken ?
If broken off flush with case a good machine shop can remove it for you. I have had this done on main studs and other bolt holes on my KZ 1000 a few times.
Once removed If was mine I would replace all the head studs so they all have the same amount of fatigue or stretch in them.
I once tried to replace only one stud and it kept loosening up
- Thank you received: 2749
03 Dec 2015 06:11 #701697
by SWest
Replied by SWest on topic kz1000 engine cases
Pics would help.
- mrdatsunturbo
- mrturbo Norway
03 Dec 2015 08:09 #701715
by mrdatsunturbo
Replied by mrdatsunturbo on topic kz1000 engine cases
Yes i will do some pics tomorrow, but yes my mistake was when the extractor broke off.So everything is removed from casing
but need some repair, and a friend of me have a spare emty very nice ST shaft casing.
So my guess is that it is ok to do tig welding and then do some new thread,helicoil i am not shure ?
and not shure about trust this set up when it is ready to do the torque.
03 Dec 2015 08:42 #701720
Lets see this before you start spending money on it
- PLUMMEN
- Thank you received: 104
03 Dec 2015 18:04 #701795
by PLUMMEN
Replied by PLUMMEN on topic kz1000 engine cases
If you do need a differant set of cases I dont think you will really notice a strength issue between a set of 77-78 cases over a set of shaft drive /mk II cases.
The older kz cases will be cheaper to buy.
- mrdatsunturbo
- mrturbo Norway
04 Dec 2015 00:17 #701819
by mrdatsunturbo
here is some Pictures,not very good it is my best camera
Attachment IMG_0093.jpg not found
Attachment IMG_0094.jpg not found
Attachment IMG_0095.jpg not found
- PLUMMEN
04 Dec 2015 05:11 #701848
by PLUMMEN
Yeah I dont think Id want anybody to do any welding in that area myself anyway.
04 Dec 2015 05:17 #701850
by SWest
It can be filled but it should be done at a machine shop so they can get it right.
- redhawk4
- Thank you received: 64
04 Dec 2015 05:48 - 04 Dec 2015 05:53 #701853
by redhawk4
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Replied by redhawk4 on topic kz1000 engine cases
As it's already dismantled ,switching to new cases would be straightforward at this point. A new set of cases are in the $100-$200 range generally and I'm sure could be found much cheaper in local small ads than on eBay - although Norway might be different. That would seem better value than paying someone to fix this problem at a machine shop and likely give you more peace of mind about the end product, unless you feel you need to keep the original engine number..
1977 KZ650B1
1980 Suzuki SP400
Last edit: 04 Dec 2015 05:53 by redhawk4.
04 Dec 2015 05:59 #701854
by SWest
It's not the end of the world. It could be filled then using the bearing and cap, a new hole can be started and tapped. Any competent machine shop can do it. I've seen worse.
- mrdatsunturbo
- mrturbo Norway
04 Dec 2015 09:41 #701877
by mrdatsunturbo
Ok so back to the question about KZ cases, is ST upper case compatible to my z1r engine?
i will visit a Welding shop on monday and ask them.
Thanks everybody have a Nice weekend and i will post the solutions.
