Kz305 interference engine?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz305 interference engine?
23 Jun 2015 04:52
#677851
One thing at a time.
  • Janz3n
  • Janz3n's Avatar Topic Author
23 Jun 2015 05:34 - 23 Jun 2015 05:35
#677854
oh i know. just looking at the possible causes. the thing started right up this morning. cant get over how easy it is to start cold now.
forgot to mention that it felt like the starter was struggling to crank last night too. almost like the engine was seizing. which has me worried.
81 kz305 ltd
Last edit: 23 Jun 2015 05:35 by Janz3n.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jun 2015 05:56
#677855
Take the oil fill cap off and smell for gas. Too rich.
  • Janz3n
23 Jun 2015 17:43
#677996
Thought I knew what I was doing when checking the timing on the points but I don't. How do I do it with a test light?
81 kz305 ltd
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jun 2015 17:58
#678000
Set them at .014 at full open. turn the crank until the light goes out at the F mark. Adjust accordingly. Clean them first.
  • Janz3n
23 Jun 2015 18:11
#678004
So the left side f mark light goes out and right side f mark light goes out? Just to clarify, to set the cam timing I was supposed to use the L mark right. That's what the manual said at least. Took it for another ride without adjusting and it wouldn't start back up withing 5 minutes.
No gas smell from the crankcase. But there was a noticeable noise from the bottom end that wasn't there yesterday. That's probably not good. Oil level was good.
81 kz305 ltd
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jun 2015 19:30
#678011
T mark for cam timing. Top dead center.
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
23 Jun 2015 19:41 - 23 Jun 2015 19:43
#678013
This has been an interesting thread to follow, but did we ever get an answer to the thread title?
Last edit: 23 Jun 2015 19:43 by TexasKZ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jun 2015 19:48
#678018
I think he's about to find out what that means.
  • Janz3n
24 Jun 2015 03:32 - 24 Jun 2015 03:34
#678048
i do believe you're wrong about that.
[IMG
im pretty sure ive got the cam timed correct.
swest wrote: T mark for cam timing. Top dead center.
the reason i ask about the static timing is that i watched a youtube video and the guys light went on at the mark. mine was going off. i just found the procedure in my manual and its exactly what you said so i'll try it out tonight. I have also just realized that ive been turning the engine clockwise even though its supposed to be counter clockwise and its stated right in the manual. oops.
81 kz305 ltd
Last edit: 24 Jun 2015 03:34 by Janz3n.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jun 2015 07:50
#678081
That's odd. I worked on a Aprilla that had the cam turning in the opposite direction. The marks were non existent. I had to get the manual. Turns out the counter balancer gear turns the cam gear and chain. :huh: I was pulling my hair out over this thing. Finally got it timed but the Alternator rotor bolts had sheared off. (Cheap bolts) Put in hardened bolts, still no start. :angry: Automatic compression release. Used starting fluid and it started. Got it running, starts every time and gave it back to the owner. He sold it before anything else went wrong with it. :pinch:
Not impressed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jun 2015 07:55
#678082
Oh, the cam chain adjuster is hydraulic, loose power, cam chain skips. :angry:
