- Thank you received: 35
what do i need to hit 100 whp?
- donthaveakawman
- Visitor
- lushbaugh
- everybodys a pro......
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- wireman
- Thank you received: 299
How about a whole lot of displacement with some boost to go with it?donthaveakawman wrote: there really is no good replacement for displacement.
Oh wait Ive already been down that road! :woohoo:
Ill stay with the gpz1100 motor in the 750 frame idea,tons of power and still run it on pump gas
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- davel
Here's a guy who already tried some of this and has real numbers oldskoolsuzuki.info/uk_lee/Thebikes/GPz/GPzDyno.htm
The dyno test he posted shows 67rwhp and 45lbft of torque. Looks like the engine made about 58hp in stock form and he ultimately got it to put out 72rwhp and 50 lbft using a head with bigger valves and bigger cams.
On the other hand, the 750 Turbo made about 90rwhp stock. Minor tweaking to boost pressure could get you over 100 easily. From there, sky's the limit. Here are some guys that know what they're doing with a 750 Turbo www.750turbo.com/fastones.htm
- donthaveakawman
- Visitor
kz750 is factory rated of 74 horsepower in 1980 a jet kit advertised that I looked at will give you another 8 percent with a k&n filter for the airbox and an exhaust, a stage 3 will get you 10-15 percent gains with a expensive exhaust and pod filters which 74 x .15 will not even get you up to 90 horsepower.
- nads.com
- Thank you received: 20
wireman wrote: 83-84 gpz1100 motor with a good header
A small kz head that flows 88cfm can produce 130hp.
A plain j head (not gpz) flows 84cfm stock and can produce upwards of 130hp
A 750cc head that flows what? 55 or 60 something cfm should allow 100hp?
Hey ask the elephant! NOt only he take out the garbage, he tells you how many shots
of nitrous you need as he bites through your tootsiepop.
Wire man brings nuclear weapon to squirt gun fight AGAIN! :woohoo:
- donthaveakawman
- Visitor
ちょっとDEEZは、彼が彼の最後の名前の背面を望んでいると呼ばれる 83 gpz1100 puts out over 100 hp, I don't know where you got your numbers from but somebody should put you through college
- donthaveakawman
- Visitor
cherokeekid58 wrote: Just out of curiosity how hard would it be to turbo my bike? I have a TD04L lying around. but id imagine thats to big of a turbo.
And tracks are for racing, not streets.
Also do they even allow turbo bikes in the vintage race class? So i guess i wont hit 100hp. But how can i increase torque? The bike has pretty good pull coming out of a corner in 2nd or 3rd gear but top of 4th is where she just kind of levels off.
Like i said im building to to be a cafe racer, so light and manuverable with decent power. I dont like top speed i like the acceleration. So i guess i should of made the title, how to get 100 foot pounds of torque lol.
Cheers
Jason
The problem with a turbo is turbo lag, its going to take a while for the turbo to kick in and when it does you may have to chase down your bike. I would definitely go with a blower if forced induction were my route.
- wireman
Cheers
Jason
Attachment dog_2013-01-13.jpg not found
Have you ever ridden a turbo bike? :whistle: :whistle:
- Thank you received: 2098
8.4 seconds later, Nads had chased down and remounted the bike, to resume lead position and win the race!
Not just anybody is capable of performing such feat.
- wireman
