what do i need to hit 100 whp?
- steell
If you want a turbo 750, then buy a 84-85 Kawasaki 750 Turbo
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- wireman
- Thank you received: 299
- ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- cherokeekid58
What do you guys recommend, a 4-1 or 4-2? Also at what point do you need to have your crank welded? I heard that if you go higher than factory revs, you should get the crank welded? Whats the reason behind this?
Oh and lush, those turbos are huge! Lets throw the whole 100 whp thing out the window. I wanna be competative at the track. To swap in a 530 chain, does it need to be off set so it matches up straight? Or can someone provide a link to a 530 chain swap thread already made? Thanks guys
Cheers
Jason
Hahaha and i thought my JEEP addiction was bad; my Kz addiction is just as bad!!!
www.kzrider.com/filebase/cat_view/102-1982 ,
- mark1122
- Keep twisting it
- Thank you received: 109
cherokeekid58 wrote: Thanks for the replys guys. Im going to get a rule book. I was thinking about doing a progressive suspension set up but i dont know what kind of rear shocks/springs to do. As for the engine ill just stick with what i originally was gonna do, exhaust, pods, etc.
Cheers
Jason
if your going racing, u dont want progressive springs. those r for cruisers that want a smooth ride. look into Racetech's gold valves and there recommended springs. or upgrade the forks all together.
4-1 vs 4-2-1.
a 4-2-1 spreads out the power curve, and cleans up the power dip at 5000rpm. it will likely be very hard to find 1 to fit and old bike. just get a 4-1, racers dont go under 5500 rpm.lol
check with turbo guzzy on the need for crank welding . generally, on a kz1000 , u would weld the crank if u r adding compression and heading to the drag strip. its the added torque applied to the crank more so, than rpm's. stockers r find as is.
going from 530 to 630 only requires new sprockets and chain.
an offset sprocket is only required if u miss align the rear sprocket. like if u changed to a dif rear rim to accept a wider tire. then u would offset the front sprocket outwards to re-align it with the rear.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Im guessing the 750 has 1 piece crank like a 650,no pins to weldcherokeekid58 wrote: Thanks for the replys guys. Im going to get a rule book. I was thinking about doing a progressive suspension set up but i dont know what kind of rear shocks/springs to do. As for the engine ill just stick with what i originally was gonna do, exhaust, pods, etc.
Cheers
Jason
- baldy110
- Thank you received: 512
- mark1122
- Keep twisting it
baldy110 wrote: Here is the easiest way to get 100+hp from a 750. GPz1100 engine in a 750 frame.
OH so SWEET. :evil:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
193 horsepower,113.+ foot pounds, and 188+ mph 2011 zx14.893cv wrote: You need to trade in your kz750 for a zx14 if you are looking for 100 ftlbs. It's not possable to get that kind of power from an 8 valve air cooled four, even with 810cc's.
why pay $4000.00+ for a turbo kit, pay $75/hour to have someone put it on, and tune it, then still have a $2000.00 bike.
- wireman
Cfm calculator? :blink:donthaveakawman wrote: I don't think that 810 kit is going to be right for a turbo. you need to take into consideration a cfm calculator, the compression, and are the pistons forged or cast.
You can put a turbo on a high compression motor,you just run less boost to hit the same hp number.
Im gonna go out on a limb here and say most 810 kits are going to be forged,although they begin the process as a casting
