1983 KZ750, dead in the water
- tv219
Bensalem, PA
- Motor Head
- Thank you received: 391
- tv219
If I can add a side note, i tried jumping the connection on the solenoid today which turned the motor? Should it be able to start from that and get running? Wasnt succesful!
Again, I just might send you a red ale for Christmas! words cant describe!!!!
Bensalem, PA
- Motor Head
If the Stock Male and Female ends connect tightly and are clean they should make good contact. Solder them if you want to, you can always un-solder later if you for some reason need to replace the solenoid.
- gengomerpyle
- Thank you received: 17
650ed wrote:
JR wrote:
650ed wrote:
tv219 wrote: Also, just curious, can any one tell what body type this bike is? I am going to try and find a wiring manual to understand it better. Didn't know if the body type or style is important. All i know its a kz750.
I believe it is a KZ750-L3. Ed
I was thinking either that or an 82 GPZ 750 www.bikepics.com/kawasaki/gpz750/82/pics.asp
So hard to tell with all that black
I think the GpZ 750 had clip-on style handlebars rather than a single bar. If it's an '83 KZ750-L3 the fairing has been added (maybe from a GpZ) to make it look very much like a GpZ. Maybe the VIN would shed some light on it. Ed
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2829
Take a look at the triple tree for your bike in the parts diagrams on Kawasaki.com. The upper section is unique to the GpZ750-R1, but the lower section (including the tube) is used on the KZ700-A1, KZ750-L3, and GpZ750-R1. This means it is possible that the upper triple tree piece from the KZ700-A1 or KZ750-L3 might fit on the lower part from your bike. The upper section is what the handlebars clamp to. IF the top of your fork tubes are compatible with the upper half of the A1 or L3 you might be able to swap the upper half of the tree and this might allow you to install bars instead of clip-ons. Or I might be totally wrong on this. Ed
- tv219
Bensalem, PA
- gengomerpyle
650ed wrote: gengomerpyle wrote: "I would love to get rid of the clip ons on my gpz and go with a superbike bar."
1982 GPZ750R1 ELR
1971 Honda CB750K
- Motor Head
- tv219
www.amazon.com/dp/B008UUW4TW/ref=asc_df_...8UUW4TW&linkCode=asn
discount-starter-alternator.amazonwebsto...FIND&affId=the005-20
thanks for you help
Bensalem, PA
- Motor Head
- tv219
Also, to update you, i noticed today when looking at the fuse box, that when i jiggled it it was shortening the headlight and turn signals. however the glass fuses were fine. They had continuity in all three of them with no resistance, i tested everything.
Bensalem, PA
