- Thank you received: 2098
1983 KZ750, dead in the water
tv219 wrote: Just curious as for tonight I will check the charging system. If the charging system was not properly working or charging, would the battery still have enough juice to have the lights working on the bike? Such as turn signals and headlight? Thanks.
Yes, provided it's a good fully charged battery, until the battery runs down.
A good fully charged battery will power a bike's ignition system for quite a long time.
Some road racers run with a total loss electrical system without any charging components.
A good fully charged battery should be used when testing.
Too high may result from a defective regulator (or faulty wiring).
Too low may result from a defective rectifier and/or alternator (or faulty wiring).
- Del_Herring
- Thank you received: 29
1983 KZ750-N2 Spectre
- tv219
Bensalem, PA
- Thank you received: 2829
tv219 wrote: Also, just curious, can any one tell what body type this bike is? I am going to try and find a wiring manual to understand it better. Didn't know if the body type or style is important. All i know its a kz750.
I believe it is a KZ750-L3. Ed
- JR
- Thank you received: 448
I was thinking either that or an 82 GPZ 750 www.bikepics.com/kawasaki/gpz750/82/pics.asp
So hard to tell with all that black
I think the GpZ 750 had clip-on style handlebars rather than a single bar. If it's an '83 KZ750-L3 the fairing has been added (maybe from a GpZ) to make it look very much like a GpZ. Maybe the VIN would shed some light on it. Ed
- tv219
Second note, the vin says its and 83'. But no specific body type came up. Thanks
Bensalem, PA
- tv219
Bensalem, PA
- BRABBIT04161991
- BRABBIT04161991
- BRABBIT04161991
