1983 KZ750, dead in the water
- tv219
Bensalem, PA
- Thank you received: 2098
Here's a link to the wiring diagram in KZrider's FILEBASE:tv219 wrote: ...am going to try and find a wiring manual to understand it better....
Click > www.kzrider.com/filebase/doc_download/316-z750l3
- tv219
lol no that's a flasher relay it shouldn't have any impact on why it's not starting. There's a lot of corrosion all over the place (white stuff) take some cola and a old tooth bush and scrub it clean. Is the white stuff all over the battery posts?? or wires??
However there doesnt seem to be any more corrosion anywhere else in that area. The flasher relay kinda got everywhere. Battery posts are clean.
Bensalem, PA
- BRABBIT04161991
- tv219
Bensalem, PA
- BRABBIT04161991
- tv219
Bensalem, PA
tv219 wrote: ...found no flasher relay....
"Flasher relay" likely refers to the flasher itself.
- Motor Head
- Thank you received: 391
If you have the two big terminals hooked up correctly, then you should be able to jump across them with a socket extension and have the starter turn the engine.
- BRABBIT04161991
- Charles Nix
- 1981 kz 1000c4
- Thank you received: 5
- tv219
If A is true in the basic sense (sparks or engine does something), what does that mean? good newsbad news lol?
If B is true.. etc etc what does that mean... And again THANK YOU SO MUCHHHH!!!!! i might even drive this to your houses and delivever my homemande red ale. THANKSSS :laugh:
Bensalem, PA
