- Thank you received: 20
Timing and powerbamd
- nads.com
slost her dinner and it's obvious. It's all over the highway. I'm heading into the sunrise, a small blip. Man on the busa is crying by the road side , holding his fist in his hand, his tank littered with dents. AND ooooo the payments! I'm in the house. ON board. Ready for action, and it's my turn to say sorry. Sorry dude guess your not old enough for rated rr yet. Little dust just came off the bottle. oocha wawa
- KruZer
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- PLUMMEN
- Thank you received: 104
right betweenthe 3rd and 7th beer! :blink: :woohoo:The question begs to be ask....where did you set the timing?
Buzz
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Old Man Rock
- Thank you received: 225
Damn this thing must of completely jumped off the ground when ramming into 3rd..... :woohoo: Yeah I guess this pulled your ass backwards no doubt.... :blink: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
Buzz
And her I was thinking it was between the 8th or 10th doobie :woohoo:
- larrycavan
- Visitor
i wanna "powerbamd"...if they are that goomd...whamt ism itm anmd whemre canm im ormder omne
Otto's probably got some "powerband-in-a-can" that should do the trick for ya
If you want your motorcycle to go really, really fast, just pour 17oz into your gas tank. Of course that means you'll have less room for gasoline but that won't matter cause the rocket juice is really where it's at and who really cares about octane anyway when you have the good juice that jolts the pistons like they're a naked fat lady on roller skates on her way to the burger stand for some fries and greasy meat but her ankles are too weak to hold her fat legs steady on the little skate wheels. Not that it matters much what the fat burger chomping lady had for lunch 'cause with the new rocket juice in your rod you can pick up some way hotter chicks anyway that love to ride on juice powered bikes because the new powerband really get's 'em moist where it matters most and if she's got a sister you might get yourslef twice the fun for the price of one and that leaves more money for more powerband juice if you're getting the picture....WHEW!!!
- Kidkawie
- I bleed premix
- Thank you received: 245
Buzz
:laugh:
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
Dude, you have way overdosed on your medication.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
84 kz 700 a1
82 kz550 ltd
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Every motor is different & every motor has different needs.
Every motor has hidden power, it depends on how determine you are to find it.
When it comes to motors, money will only take you so far.
When it comes to racing engines, they all have some of the same parts or builders. What makes one faster then the others?
I see many threads on cam degreeing on this site. What always comes to my mind is! People should spend some time indexing their spark advance.
While you have the degree wheel on the motor, check the timing marks. You may want to add some "advance or retard" timing marks. This will allow you some flexability down the road.
I suggest a true 5 degree mark each way....just as a baseline. 5 degrees is a lot! you may only need a couple of degrees. You can eyeball it for a touch less then 5 degrees.
If you ever sell or lose the motor, good notes are needed if you plan on replacing it. You might remember all the specs & part # today, what about in five years?
- WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
