Timing and powerbamd
- KruZer
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- nads.com
- Thank you received: 20
- TerryK
- Thank you received: 3
What color is the power band?? I have a purple one in my bike but I don't think it has enough Marsilvain tension to prevent side fumbling of the lunar wainshaft because my 1000 will only do 85mph in second at 13,000rpm.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Old Man Rock
- Thank you received: 225
What gear (sprocket tooth counts) ratio are you running?
I would think @ 100mph in second gear this thing must be screaming & whining "Shift me damn it" something fierce.... :S
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
trianglelaguna wrote:
i wanna "powerbamd"...if they are that goomd...whamt ism itm anmd whemre canm im ormder omne
Otto's probably got some "powerband-in-a-can" that should do the trick for ya
If you want your motorcycle to go really, really fast, just pour 17oz into your gas tank. Of course that means you'll have less room for gasoline but that won't matter cause the rocket juice is really where it's at and who really cares about octane anyway when you have the good juice that jolts the pistons like they're a naked fat lady on roller skates on her way to the burger stand for some fries and greasy meat but her ankles are too weak to hold her fat legs steady on the little skate wheels. Not that it matters much what the fat burger chomping lady had for lunch 'cause with the new rocket juice in your rod you can pick up some way hotter chicks anyway that love to ride on juice powered bikes because the new powerband really get's 'em moist where it matters most and if she's got a sister you might get yourslef twice the fun for the price of one and that leaves more money for more powerband juice if you're getting the picture....WHEW!!!
Ha-Ha-Ha Laurence, you'r real funny. I love you too. :kiss: :laugh: No, no powerband in a can. :S
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- sparkn
Stock timing marks are just like stock spark plugs or stock valve timing. They are a compromise to give you the best all around experience as the manufacturer defines it for you.
There are so many variables affecting where the optimum timing should be including engine temperature, engine speed, engine load, volumetric efficiency, type and quality of fuel, etc. with the answer to the equation being that the fuel should be fully burned at about 20 degress ATDC.
Non-computerized ignition systems without vacuum advance ONLY use engine speed to determine optimum timing. Add a vacuum advance and you get another variable taken care of (in a "best guess" kind of way). Throttle position sensor takes care of another. Knock, oxygen, and MAF sensors take care of other variables. Is it any wonder that todays computerized engines can deliver more power with better fuel mileage and reduced emissions over a wider range of driving styles? All of those sensors combine just to determine optimum fuel delivery and...spark advance.
1979 KZ650 SR
- otakar
I have a final ratio of 2.22:1 (18/40 sprockets). I can attest that i have to slip the clutch like crazy and rev the engine from a dead stop to role. I believe I have more than normal HP in the bike. In first gear at 9K I am doing 66mph. In second gear at 9k I am doing 96mph. third gear I can do 101mph at 7.4k and 123mph at 9k. These are measured with a GPS. I find that my speedo is only a little off, and my tach is electronic, taken off the coils. I would have to be turning 13.55k to be going 100mph in first and 9.4k in second to be going 100mph. I think that he might be going 100KPH in first turning over 10k. And, since when dose "retarding" your ignition give you more power at top end????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- sparkn
1979 KZ650 SR
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- KruZer
Thanks for sharing the print out.
Can I ask what pitch chain you running?
Thanks,
Buzz
- Motor Head
- Thank you received: 391
Man I thought 140mph in a car was pretty fast, when those corners just seem to come up so quick!
- otakar
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
