Timing and powerbamd
- sparkn
1979 KZ650 SR
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
And, since when dose "retarding" your ignition give you more power at top end????[/quote]
Since the start of time!
Advancing the timing gives you more bottom end/mid range.
Retarding the timing gives you more mid range/top end, increasing your MPH.
MPH is the weak point of these motors.
- Thank you received: 2829
In that case, couldn't the spring rates on the advancer be modified so the timing advance takes place at a slower rate? If this could be done, the advance could be set a little higher at low RPM (giving best bottom end/mid range) and would still not advance so far or as fast as the RPMs increased (giving more mid range/top end).
- otakar
MPH is the weak point of these motors.[/quote]
:ohmy: ????????? That's the first time I have ever heard that? I was always taught that low rpm requires low advance and hi RPM requires large advance. Than, I wonder why the timing advancer on the engine is not made to work the other way around from the way it is? I've learned something new here after 34 years of working on these bikes. Thanks for that info.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Actually the advancer should be reversed, so it retards the timing as the RPM gos up. ????????????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
- Thank you received: 391
You didn't get to Dyno that motor did you? Those are sure some tall gears. A Dyno sheet would make some interesting reading if you have one to post.
Timing curve, Initial advance-Total advance, , curve goes up, only a vacuum system would incorporate a Retard, at Idle, for emissions. But sometimes Total advance is to much, so backing it off, and shorting the curve, so the Initial setting is unchanged works best.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- steell
Strange things happen sometimes, read a story (think it was in Camerons book) that talked about legendary Harley factory tuner O'Brian (sp?) being amazed at a Harley motor he was helping a friend tune, max power was at something near 11 degrees advance total.
- Motor Head
Mechanical systems still like a good tuning. The Hot Headed Air Cooled KZ motor seems like a good candidate for somewhere around 32-35 degrees total. But 40 sounds a bit much, so I can see where nads.com was coming from on the thread.
A lot of the racers in the past used to get rid of the advance weights or springs and weld the distributor plate. Then tune just for total advance, as these don't stop and go like a street machine.
Otto;
Yea I read about the Job, it sure will be nice to go back to work!
The last one I had sucked, so I dragged up. I hate it when they gouge customers. Back to flipping Cars and Bikes for a bit of cash, all on the up & up, legal and all.
- kzz1p
:ohmy: ????????? That's the first time I have ever heard that? I was always taught that low rpm requires low advance and hi RPM requires large advance. Than, I wonder why the timing advancer on the engine is not made to work the other way around from the way it is? I've learned something new here after 34 years of working on these bikes. Thanks for that info.[/quote]
I am not talking about the advancer........
