- Thank you received: 225
Engine Temperature
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- BohicaBob
- Thank you received: 35
- dejavoodo41
- Kawickrice
- Thank you received: 18
1 trip down Main Street during Bike Week was all the convincing I needed that an oil cooler was next on my list of mods. It was one of the coldest Marches on record and all of the stop and go so little people with big bikes could get them up on the sidewalk really got the Ole Girl heated up and I wasn't the only one saw a couple of Shovels and Evos that were so hot they were starting to smoke and their owners were oblivious to the fact that they were destroying their engines. During normal street riding I haven't had any issues but that stop and go stuff has convinced me that a cooler and possibly a fan are in order.
Here is a vidio I took with the cam mounted to the fork ears of my Z1 going down main st Daytona a few years ago. This is true stop and go and an evil heat maker.
[youtube][/youtube]
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- davel
The oil cooler is effective but doesn't do much unless you're moving. I've found it more important to keep air moving over the engine. There isn't enough oil circulating through the cooler to keep the engine temp down especially at low RPM
- bountyhunter
- Thank you received: 337
That only applies to dino oil. Synthetic (real synthetic) was designed specifically for aircraft engines that literally cooked regular oil in minutes. Real syn oil will not break down at temps that would fry your engine.Interesting indeed... One thing for sure... Oil is kept at cooler temps, oil breakdown is decreased thus engine runs smoother thus equates to cooler engine temps.....
That said, a lot of oil sold as synthetic is actually dino oil run through a filter thanks to a court ruling but that's another problem..... real syn oil will live way beyond where the engine will not.
- bountyhunter
Good point: the oil cooler blocks airflow to the head and "pre heats" what air it does get.... there ain't no free lunch in the engineering world.
- Old Man Rock
Davel, I like that design you have there, current draw on that DC fan?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- davel
OMR
It's listed at 4.8 amps but that's startup draw. Only uses about 3 amps while running. Moves 400CFM air.
www.summitracing.com/parts/DER-16507/
- davel
Yeah, I've thought about this and have considered moving the oil cooler behind the cylinder block between the intake filters and rear wheel. Never seen it done but there's enough room, it's a lot closer to the the oil pump and it leaves the head completely unobstructed from cool air flow....maybe later this season.
- PLUMMEN
- Thank you received: 104
i doubt cooler would do much good on back side of motor since it would just be picking up air heated by the motor,i still wonder if a fan mounted behind motor would be more affective though as a puller instead of a pusherbountyhunter wrote:
