- Thank you received: 540
Engine Temperature
- MFolks
Oil needs to get hot enough to boil out the moisture created from combustion. Water boils at 212 F (100 C) so I think a bypass valve would be the smart way to go if planning on an oil cooler.
Some other oil cooler suppliers:
Oil Coolers & Accessories
www.batinc.net/mocal-central.htm
www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
- bountyhunter
- Thank you received: 337
- bountyhunter
There are two kinds of coolers: shunt and series. The ones I saw for aftermarket were shunt, where a small amount of oil pressure (and oil) is "tapped off" at the sensor location for oil pressure. About an extra quart of oil is added and runs externally through the cooler and returns to the pan, but normal internal oil flow is unchanged. In that kind, a thermostat would block that external flow to the cooler when cold and open when warm.It is possible to over cool the engine oil, perhaps a bypass installed in the lines would moderate the oil temperature.
If it is a series cooler, then all of the oil is run through it and you would want to bypass the cooler when cold. You couldn't block the cooler line in that case.
- Kawickrice
- Thank you received: 18
I read that's how a lot of engine damage occurs: if the engine runs a while but doesn't get hot enough to disperse the water, it forms acid with combustion byproducts and eats up the engine. That's the reason it's not good to have only short trip runs.
This is very true. The old cars used to rot the muffler off from making short trips consistantly, now there is a small hole drilled in the bottom of the muffler for the condensation to drip out.
As far as my oil cooled bike I tend to run it hard and for longer trips, for short grocery trips I ride my air cooled Zuk
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
- Thank you received: 225
Same time, when I performed those measurements, as BSKZ650 noted, only 92 out and the engine temps where way up there, oil was 251*F... :blink:
If I recall correctly, yeah I know right.... 220-230 was about the max for oil temps...
All I know, my old girl is happy I did....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
my cbr6 only runs at 187*F, 86*C on the track .
Not sure anymore what car thermostats are set at? im sure some here will help.
The bypass thermostats mensioned above are set at 180* F.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Can't say for your areas but here in AZ, mild performance build and ridiculously hot temps, yeah it's needed...
A mild performance build does not include porting
I think whatever is required is required.
Check + monitor your oil temps and if they're constantly too high for your likeing, than install a cooler.
Or jet the bike richer, but thats not always a great alternative.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- T_Dub
- Thank you received: 25
But I guess my build isn't very "mild" either.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- nads.com
- Thank you received: 20
Is the rocket bike faster than your z??Oil does not need to run at 212* to boil off water.
- testarossa
- Thank you received: 82
Mark, most newer cars use a 195* thermostat, but that's just the water temp. My ZX-10r will maintain mid 180's if you can keep moving. Under 50* ambient temp. it wont even get to the 170's while moving. However, while sitting in traffic on 90*+ days it can touch 230*. Damned electric fan can't move enough air to keep the temp down.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- mark1122
- Keep twisting it
so i guess we can assume that the normal oil temp should be around 170* to 195*for a water cooled motor.
obviously an air cooled can get hotter. if it has some compression u dont want it to get any hotter if u can prevent it, u should , by adding a cooler.
I believe omr is right about oils max temp. not sure what the # is, but a synthetic will def take the heat better than a dyno oil..
i'm thinking that dyno oil will break down fast at 250*.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
