Engine Temperature
- KZJAKE
- Old Man Rock
- Thank you received: 225
Can be as reviewed in recent testing here in AZ on my KZ.
Pre & Post synthetic oil and oil cooler....
Maybe will give you some idea on yours...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
- Thank you received: 337
- bhardy501
1980 KZ1000B LTD
- hocbj23
- Visitor
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If your going bigger block, extra lift cams, extra, extra, blah... Then you might really want to consider one.
EITHER WAY, start with one of these:
Not too expensive for peace of mind, from American Classix
It replaces your oil filler cap! Cool, I know!
Then you can see if you ever need an oil cooler upgrade.
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- BSKZ650
You can feel the heat coming off the engine and any time you have a oppertunity to reduce the oil temp I would take it, unless you live in a cold climate.
I was riding Monday, and at lights I really noticed the heat.
- hocbj23
- Visitor
- bountyhunter
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- davel
Any one know how hot should a KZ 650 engine get. I check mine after a 10 mile ride as soon as I shut it down. It was about 270 degrees on the head and about 200 on the crankcase. So is this right or what? The outside temp was about 85 degress.
270 on the head and 200 at the crankcase (engine oil temp) are normal for an air cooled engine.
Temps can get to about 350 at the head and 250 at the crankcase without issue. Above that and you'll start to get signs of overheating. pinging, eratic idle, stalling at idle, or worse...
btw have a look at the picture Tek posted. That's a crankcase oil temp gauge. Note the red line at 250...
