- Thank you received: 225
Engine Temperature
- Old Man Rock
OK, here's a question... If the thought is coolers are not truly needed, then why did the Kawi engineers design KZ's with them?
Best assumption would be after they had been out on the market awhile, they most likely realized that this was beneficial/required after analyzing the data. Different riding styles due to power, speed, different environments, engine component breakdowns etc...
No flame war guys for it is an interesting discussion...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
Is the rocket bike faster than your z??
they are close. a very dif kind of power though. the cbr, even my pals Honda 919 doesn't FEEL more powerful, because the delivery is so smooth. the kz is a raw torquey type of power. u are constantly reminded of power with the z, due to the torque, but the honda's fool u because there so smooth.thats how u can get into trouble, u dont realize how fast u are going and then:woohoo:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- hugo
- '92 Zephyr 750
- Thank you received: 71
Mostly the oil coolers are not really to cool the engine, but to prevent the oil from getting too hot and loosing its lube properties, if bike is ridden hard.
Oil coolers in hi-performance motorcycles acts somewhat like the auto trannies fluid coolers in cars, picking up the extra heat generated by the wet clutch, which uses the oil as cooling media, hence the term 'wet clutch'. Oil is not there to 'lube' the clutch, but to cool it. (In a car is the torque converter). Like in a car with auto tranny, you can live w/out the cooler, but anything that contributes to control temperature, promotes longevity, thus is an intangible, but useful if you plan on keeping the bike long time.
Even hi-performance LIQUID COOLED motorcycles come with oil coolers because the oil still has to lube the tranny and cool the clutch. Honda, Kawasaki, and Yamaha favor a coolant-to-oil coil buried around the base of the oil filter. Suzuki and Triumph favor air-to-oil cooler as you can see on the chins of GSX-Rs 1K, SVs 1Ks, or Trimph Speed Triples.
- bountyhunter
- Thank you received: 337
You answered your own question: they designed bikes around the coolers which means they can hop the engines up more and make the total package size smaller. The point is that bikes/engines designed to NOT use coolers don't need them unless they are hopped up or used in extraordinarily severe service like LE. As correctly pointed out, their main objective is to keep the lube from being destroyed by heat and modern syn oil doesn't need that rescue.Keep in mind all... My temp measurements where at 92*F, wait till I re-measure at 110*F :blink:
- mark1122
- Keep twisting it
the oil may not need the rescue, but the combustion chamber may.Old Man Rock wrote:
if u raise the compression, u may get detonation, as some guys report. the cooler can only help in these situations.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
Still later year stock OEM KZ's and GPZ came with coolers... Thinking there was more to there reasoning...
Interesting indeed... One thing for sure... Oil is kept at cooler temps, oil breakdown is decreased thus engine runs smoother thus equates to cooler engine temps... My pre & post temp measurements tell me that alone.
For those that live in humid areas... Say 90*F but 95% humidity, ever accomplished temperature measurements?
Would be interesting to see the results...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Old Man Rock
That would be perfect & please do share your results...
If you use similar format as to the measurement points I used, please add carb float bowls...
Larry C had asked about that and I just didn't think of it... Will add to the next 110*F + test coming up next moth or so...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- testarossa
2004 ZX-10R
Angola, IN
- Old Man Rock
When ever you get around to it, no rush on my part at least... More info, data, testing the better for all...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- testarossa
2004 ZX-10R
Angola, IN
