1977 KZ 1000 b1 LTD running rough
- davelKZ1000
04 Apr 2010 19:33 #358460
by davelKZ1000
Replied by davelKZ1000 on topic 1977 KZ 1000 b1 LTD running rough
i put a half can in the gas tank and ran the tank dry. i put a couple ounces in the oil as well. i rode it hard even when up to the top of a small mountain here in NH.
It did not like the mountain much. my buddy said i had blue smoke coming out the left pipe.
I get the most popping backfireing when its cold.
with the bike up over 3500 rpm it runs much better.
If im at 3500 and i goose it the kz just takes off like a rocket every time. at this point i believe it has to be running on all 4.
I took new compression readings. after my ride. i did forget to take them after the valve adjustment.
1-4 left to right was 120 120 120 125. i put a little oil in the plug whole of #1 and the compression came up to 140 on that cylinder.
- davelKZ1000
06 Apr 2010 16:38 #358820
by davelKZ1000
- davelKZ1000
06 Apr 2010 16:39 #358821
by davelKZ1000
- davelKZ1000
06 Apr 2010 16:41 #358825
by davelKZ1000
another thing i noticed was the the main jets o ring in number one was a little chewed up and the jet did not seat as well as the others.
I will never buy an aftermarket rebuild kit again.
- davelKZ1000
06 Apr 2010 16:42 #358826
by davelKZ1000
- MajDSaster
- Thank you received: 1
15 Apr 2010 18:49 #360964
by MajDSaster
Current Ride: 2005 Kawasaki Vulcan 750
4th Ride: 1981 Kz1000 LTD (2008 - Storage)
3rd Ride: Wife (1999 - 2005)
2nd Ride: 1982 Kz1000 LTD (1983 - 2004)
1st Ride: 1977 Yamaha SX-650 (1981 - 1983)
Replied by MajDSaster on topic 1977 KZ 1000 b1 LTD running rough
Hey Dave, When I forst got my Kz1000, it had been sitting for a few year too. Gas tank had a couple of inches of rusty sludge. Drained and flushed out tank, replaced petcock. Drained carbs and still do every few day just to see what comes out.
I initially had a lot of smoke from the exhaust and popping and backfiring. After a few day of running on hi-test with a bottle of fuel injector cleaner in the tank it stopped popping and smoking.
Still had a problem with #4 cylinder cutting out and sometimes #1 or both. Just replaced all the sparkplug cable with wire core cable and new plug caps and she doing pretty good.
After reading stuff about Seafoam on here, I think I'll get me some!
- davelKZ1000
17 Apr 2010 20:26 #361413
by davelKZ1000
My tank is really clean....I have inline filters......I'm waiting on some parts but I believe my problem is a missing needle jet in Carb 1.......well see.....thanks for the tips
