1977 KZ 1000 b1 LTD running rough
- davelKZ1000
- keith1
- Thank you received: 2
- davelKZ1000
front from left to right 1-4
was .002 .004 .002 less than .002
Rear from left to right 1-4
was .003 .004 .004 .004
The book calls for from .002 to .005
so i was planning on adjusting front #1, 3, and 4
where should i set them at?
What do you think?
- keith1
So I am preparing myself for this valve adjustment.
What do you think?
dave,
just remember .002-.005 is inches if using metric feelers its gonna be .05 to .10......obviously youre going the inch route...just wanted you to be aware....
if it were me ,i would use metric feelers as the shims are going to have metric measuremnts on them and the math is gonna be alot easier....but thats just me....
- davelKZ1000
i bought feeler gauges to check the points...than i needed smaller ones for the valves....now i got to get the metric feeler gauges. so funny...lol :silly:
- davelKZ1000
do you have a recomendation as to what to set them at?
Any tips on actually adjusting them?
Im still not sure i dd them exactly right.
You said turn the crank till they were 180 degrees away from the buckets which i assum is the valves....so i measure when the cames point away from valves... is that right?
The reason i ask is because the book says to line up the marks on the came chain sproket measure two than turn one complete resolution and line up marks again and measure the other two. but when i did this there was not always two pointing away....or it was not exact.
- bountyhunter
- Thank you received: 337
those plugs are all new......
Then they have had a hard, short life.....
- bountyhunter
I run mine .003 - .005"so should i adjust all the ones that are .002 or less?
davelKZ1000 wrote:
I think that's correctIm still not sure i dd them exactly right.
davelKZ1000 wrote:
I had not heard that before. I always point the cam directly away from the valve. Also, keep turning in the normal direction of rotation and don't reverse direction as that will take the tension off the cam chain and can let the camshaft shift in the journals. On mine, it can slightly affect clearance readings.The reason i ask is because the book says to line up the marks on the came chain sproket measure two then turn one complete revolution and line up marks again and measure the other two. but when i did this there was not always two pointing away....or it was not exact.
- bountyhunter
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- davelKZ1000
- roy-b-boy-b
- Thank you received: 103
