1977 KZ 1000 b1 LTD running rough
- davelKZ1000
- BSKZ650
- Thank you received: 14
never et the pic on the first try
go buy a new set of plugs, those look old and you really cant trust them especially when you are chasing firing issues,
next, get the voltage fixed going to the coils, since two cyls fire from one coil, if its weak, it will only fire one, electricity is lazy it takes the least path of resistance.
the pipe looks like its got a lot of oil on it, could be from sitting so long and the rings are stuck or since you have a cyl not firing its gonna try and pump oil and fuel.
as stated before, do a COMPLETE tune up, new plugs, point condensor, clean carbs again, check for vacumm leaks, and adj valves, get full voltage to the coils, eithe via the wired george coil mod , or cleaning all connection.
you would be surprised how one small item can drive you nuts when chasing a missfire issue
77 ltd1000, current rider
76 kz900, just waiting
- davelKZ1000
When I check the volts to the coil is that with the engine on or off?
- davelKZ1000
- BSKZ650
When I check the volts to the coil is that with the engine on or off?[/quote
key on, in the run position, engine off,, just dont leave it on for a long time, you are putting voltage to the coils and condnsers.
you should have close to the same voltage at the battery as you do at the coils
- davelKZ1000
- davelKZ1000
those plugs are all new......ill ge some new ones though
- larrycavan
- Visitor
- davelKZ1000
- larrycavan
- Visitor
Biker was later setup cafe style with Yosh Pipe, drag bars, etc.
- kaw-62046
- davelKZ1000
